DAYTON AUDIO SS12-22 Speaker Driver Woofer / Subwoofer
Avec le SS12-22, Dayton Audio présente un haut-parleur subwoofer de 30.48cm à double bobine. Conçu pour des applications à forte puissance, il associe une membrane en aluminium anodisé à un triple aimant optimisé par simulation FEA et une suspension à double spider pour proposer une puissance de sortie de 900W RMS sous 4Ω sur une bande de fréquences allant de 20Hz à 500Hz.
By buying this product you get 41 loyalty points
Reference : 21243
419,00 €tax incl.
349,17 € tax excl.
Grantie 5 ans
Dayton Audio SS12-22 Speaker Driver Woofer / Subwoofer 900W 4 Ohm 88.1dB 20Hz-500Hz Ø30.48cm
Dayton Audio SS12-22 : Front view
With the SS12-22, Dayton Audio presents a 30.48cm dual voice coil subwoofer driver. Designed for high-power applications, it combines an anodised aluminium cone with a triple magnet optimised by FEA simulation and a dual spider suspension to deliver 900W RMS power output into 4Ω over a frequency range of 20Hz to 500Hz.
Dayton Audio SS12-22: Aluminium membrane
The SS12-22 uses a thick anodised aluminium membrane, combining lightness and rigidity. This diaphragm resists deformation well, even during significant movements, and maintains strictly pistonic movement throughout the entire excursion. An indexed transition between the cone and the suspension provides additional rigidity at the edges to resist deformation and minimise unwanted resonances. The long-travel butyl rubber suspension completes this assembly, optimised to allow high excursion while maintaining an excellent emissive surface.
Dayton Audio SS12-22 : View of the membrane
Dayton Audio SS12-22 : Magnet
Dayton Audio SS12-22: 3-inch coil and advanced thermal management
The SS12-22 is powered by a 3-inch voice coil, using four layers of copper, coiled on an aluminium support. This configuration maximises the number of turns in the air gap to increase magnetic force while maintaining a reduced gap, ensuring precision. The aluminium support acts as a heat sink and contributes to stability during prolonged use. Combined with significant ventilation through the sub-cone, suspension, magnetic pole and air gap, this design limits thermal stress and allows for a rated power of 900W RMS.
Dayton Audio SS12-22: Low distortion magnetic circuit
At the heart of the SS12-22 is a large triple magnet, engineered using FEA and generating a symmetrical magnetic field. This allows the diaphragm to move identically forwards and backwards, minimising distortion even at the limits of excursion. Precision-machined plates with sculpted edges maximise magnetic flux transfer, while an aluminium short-circuit ring and a large magnetic cap linearise inductance throughout the entire stroke. The result is reduced distortion and constant, precise control of sound reproduction.
Dayton Audio SS12-22 : Magnetic circuit
Dayton Audio SS12-22 : Suspensions
Dayton Audio SS12-22: Unfailing stability
To maintain linear cone movement and eliminate any risk of tilting, the SS12-22 uses a double spider suspension, spaced for greater stability. The connecting wires are stitched into the upper spider to improve mechanical reliability and prevent unwanted contact with the cone or suspension during heavy excursions. This design, combined with the precise control mentioned above, ensures smooth piston-like movement even when pushed to its limits.
Dayton Audio SS12-22 : Spécifications
Product typeSpeaker Driver Woofer / Subwoofer
Nominal diameterØ30.48cm (12")
Power handlingRMS: 900W
Max: 1800W
Impedance4Ω
Sensitivity88.1dB 2.83V/1m
Frequency response20-500Hz
Voice coil diameterØ7.62cm (3")
Membrane materialAluminium
Suspension materialRubber
Basket materialCast aluminium
Magnet materialFerrite
Thiele-Small Parameters
Resonant frequency (Fs)27Hz
DC Resistance (Re)4.9Ω
Voice coil inductance (Le)1.8mH
Mechanical quality coefficient (Qms)3.47
Electromagnetic quality coefficient (Qes)0.39
Total quality coefficient (Qts)0.35
Compliance equivalent volume (Vas)1.74ft³
Mechanical compliance of suspension (Cms)0.125mm/N
Force factor (BL)24.3T·m
Diaphragm mass inc. airload (Mms)275g
Linear excursion (Xmax)23mm
Surface area of cones (Sd)528cm²
Information regarding assembly
Total external diameterØ32.25cm (12.7")
Cutting diameter of the baffleØ28.575cm (11.25")
DepthØ19.431cm (7.65")
Weight15.4kg
PackageSold by unit
Speaker Power (W RMS)900.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)305.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)23.0
Lowest frequency (Hz)20
Highest frequency (Hz)500
DAYTON AUDIO SS12-22 Speaker Driver Woofer / Subwoofer 900W 4 Ohm 88.1dB 20Hz-500Hz Ø30.48cm
Avec le SS12-22, Dayton Audio présente un haut-parleur subwoofer de 30.48cm à double bobine. Conçu pour des...
