DAYTON AUDIO PCS8-4 Subwoofer Speaker
The Dayton Audio PCS8-4 is a 20.32cm (8") woofer designed for building, repairing or replacing compact subwoofers. Its 3.5cm (1.4") voice coil, 4 Ω impedance and power handling of 150 W RMS, with a maximum of 300 W, allow it to be paired with many active amplification modules or passive configurations, while its frequency response of 40 to 1,000 Hz and its resonance frequency of 43 Hz ensure a rendering suited to subwoofer applications.
Reference : 22521
47,90 €tax incl.
39,92 € tax excl.
Grantie 5 ans
DAYTON AUDIO PCS8-4 Subwoofer Speaker 150W 90.3dB 4 Ohm 40Hz-1kHz
DAYTON AUDIO PCS8-4: Front view
The Dayton Audio PCS8-4 is a 20.32cm (8") woofer designed for building, repairing or replacing compact subwoofers. Its 3.5cm (1.4") voice coil, its 4 Ω impedance and its power handling of 150 W RMS, with a maximum of 300 W, allow it to be paired with many active amplification modules or passive configurations, while its frequency response of 40 to 1,000 Hz and its resonance frequency of 43 Hz ensure a rendering suited to subwoofer applications.
With a sensitivity of 90.3 dB at 2.83 V/1 m, a total quality factor Qts of 0.49, an equivalent air volume Vas of 0.72 ft³ and a maximum linear excursion of ±5 mm, it can produce a substantial bass level from moderate amplification power, while remaining compatible with low-volume enclosures. This design relies on a ferrite motor, a four-layer voice coil mounted on an aluminum former and a ventilation system running through the coil former, the pole piece and the area beneath the suspension, in order to promote heat dissipation during sustained listening.
The treated gray paper cone, the inverted dust cap and the large-roll rubber surround combine mechanical strength, excursion control and consistent finish, while the shallow-flange stamped steel basket makes integration into a baffle easier when the available depth is limited. The PCS8-4 is also the direct replacement for the woofer used in the Dayton Audio CS800 powered subwoofer, making it suitable both for restoring existing equipment and for building a new subwoofer, a bass module or a compact DIY loudspeaker.
DAYTON AUDIO PCS8-4: Measurement and dimensions
Technical specifications
Product typeSubwoofer
Impedance4Ω
Sensitivity90.3dB 2.83V/1m
Frequency response40Hz-1kHz
Voice coil diameter3.5cm (1.4")
Nominal diameter20.32cm (8")
PowerRMS: 150W
MAX: 300W
Thiele-Small parameters
Resonance frequency (Fs)43Hz
Cone surface area (Sd)213cm²
Voice coil inductance (Le)1.55mH
DC resistance (Re)3.4Ω
Mechanical quality coefficient (Qms)3.96
Electromagnetic quality coefficient (Qes)0.56
Total quality coefficient (Qts)0.49
Force factor (BL)8.4T·m
Total moving mass + air load on cone (Mms)43g
Mechanical compliance of suspension (Cms)0.32mm/N
Compliance equivalent volume (Vas)0.72ft³
Max linear excursion (Xmax)5mm
Mounting informations
Cutout diameter17.78cm (7")
Depth10.16cm (4")
Number of mounting holes8
Total outer diameter22.54cm (8.875")
Materials
DiaphragmTreated paper
MagnetFerrite
FrameSteel
SurroundRubber
Voice coil wireCopper
Recommended Enclosure Volume
Sealed Volume39.64L (1.4ft³)
Sealed F344Hz
Vented Volume56.63L (2ft³)
Vented F334Hz
Weight2.18kg
PackageSold individually
Speaker Power (W RMS)150.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)203.2
Diaphragm typePaper
Efficiency / Sensitivity (dB)90.3
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)40
Highest frequency (Hz)1000
The Dayton Audio PCS8-4 is a 20.32cm (8") woofer designed for building, repairing or replacing compact subwoofers. Its 3.5cm (1.4") voice...
