MINIDSP UMIK-2 Low Noise Omnidirectional Measuring Microphone USB XMOS ASIO 32bit 192kHz
The UMIK-2 is the second generation MiniDSP omnidirectional low-noise measuring microphone. It takes advantage of everything that made the first version, the UMIK-1, so successful, such as its Plug & Play USB interface or its calibration file, unique for each microphone for optimal accuracy.
By buying this product you get 26 loyalty points
Reference : 14846
265,00 €tax incl.
220,83 € tax excl.
Shipping date: 02-06-2026.
MiniDSP UMIK-2
MiniDSP UMIK-2 Microphone de mesure omnidirectionnel faible bruit USB XMOS ASIO 32bit 192kHz
Of course, the UMIK-2 benefits from significant improvements in performance and functionality. A 1/2" larger capsule is used to achieve lower noise and distortion, preserved by the 32bit ADC integrated in an aluminum chassis. In addition, the sampling rate is selectable from 44.1kHz to 192kHz for extended compatibility with the widest range of measurement and recording software.
The microphone is fully compatible with REW (Room EQ Wizard) and Dirac Live (version 3 and later) software. No driver is required for systems running Mac OS, Linux, Android or iOS, and an ASIO driver is provided for Windows systems for easy integration.
Unique calibration
All UMIK-2s are calibrated using a single calibration file. In addition, a unique 90 degree calibration file is automatically generated. To download the calibration files go to this page and enter the serial number on your microphone in the field provided.
MiniDSP provides two calibration files, to be used according to your audio system :
  • For a stereo system, use the 0deg file and point the UMIK-2 at your speakers.
  • For a multi-channel system or a surround application where multiple speakers are arranged in the room, use the 90deg file and point the UMIK-2 at the ceiling.
MiniDSP UMIK-2 Microphone de mesure omnidirectionnel faible bruit USB XMOS ASIO 32bit 192kHz MiniDSP UMIK-2 Microphone de mesure omnidirectionnel faible bruit USB XMOS ASIO 32bit 192kHz
Product typeMeasuring microphone
Capsule1/2" Low noise pre-polarized condenser
60 UNS
Capsule sensitivity-34dBfs @ 0dB Gain (97dB SPL, 1kHz)
Capsule noise level-1055.3dBfs (A) @ 0dB Gain
Sampling rateUp to 32bit 192kHz
SPL Max (0dBfs)125dB SPL
Equivalent input noise level (EIN)20dB SPL @ 0dB Gain
OS CompatibilityMac OSX / Linux / Android without driver
Compatible ASIO driver for Windows via UAC2 MiniDSP driver
iOS with USB Camera Kit
ADC32bit
Analog gain up to 60dB
SNR ADC120dB
Body materialAluminum
Dimensions21 x 185mm
Weight150g
Package1x MiniDSP UMIK-2
1x Shielded USB-C cable
1x Mini tripod + microphone clamp
1x Wind screen
4 reviews
Works as expected for loudspeaker measurements with REW. It was packaged well and is of good quality for the price. Cable has USB-C connector for the microphone but USB-A at the other side, so I needed to use an adaptor to plug it into my Macbook.
This review has been posted for MINIDSP UMIK-2 Low Noise Omnidirectional Measuring Microphone USB XMOS ASIO 32bit 192kHz
Fonctionne très bien
Le microphone fonctionne très bien avec le logiciel REW et le fichier de calibration téléchargeable, ça donne des mesures très précises même dans les graves et à moins cher que les bidules de Big Sonomètre qui coûtent plus de 1000 voir 2000€ où en plus il faut payer encore des centaines d'€ pour avoir l'analyse avec des octaves plus précises, ici c'est moins de 300€ et toute la précision qu'on puisse vouloir raisonnablement et +
Il faut faire attention cependant car il est recommendable de l'utiliser sur un pc portable alimenté par batterie, sur un fixe on manque de portabilité et il peux y avoir des interférences
Perfect
Très bien...utilisation professionnelle...
Excellent product, easy setup, accurate results
Perfect service by Audiphonics, excellent measurment microphone, easily set up for working with Room EQ Wizard on Windows via ASIO driver. No problem in obtaining the individual calibration files from MiniDSP. All in all, five stars.
The UMIK-2 is the second generation MiniDSP omnidirectional low-noise measuring microphone. It takes advantage of everything that made the first...
