Bass speakers-medium CRB-165PS
Reference : 1294
40,20 €tax incl.
33,50 € tax excl.
Two-coil subwoofers combine a modern finish with optimized materials. Polypropylene membranes are equipped with a special structure, giving better stability to moisture-insensitive materials.
Hi-Fi Hi-Fi Bass-Surround, 4 Ω, 70 W MAX
High-power bass and midrange, special polypropylene membrane with excellent impulse response, dust cover, lacquered salad bowl with gold-plated connections, 50-4500 Hz; combines ideally with CARPOWER's complementary high-performance speakers. Cutting 144 x 70 mm, external dimensions Ø 165 mm, type 165.
blank.gifImpedance (Z) blank.gif4 Ω
blank.gifResonance frequency (fs) blank.gif65 Hz
blank.gifMaximum bandwidth blank.giff3-4500 Hz
blank.gifMaximum power blank.gif70 WMAX
blank.gifNominal power (P) blank.gif35 WRMS
blank.gifAverage sound pressure (1 W / 1 m) blank.gif89 dB
blank.gifCompliance susp. (Cms) blank.gif0.32 mm / N
blank.gifMovable mass (Mms) blank.gif14.5 g
blank.gifMechanical overvoltage. (Qms) blank.gif4.54
blank.gif Electrical overvoltage (Qes) blank.gif1.25
blank.gifFact. total overvoltage (Qts) blank.gif0.99
blank.gifVolume equ. (VAS) blank.gif11 l
blank.gifDC resistance. (Re) blank.gif3.6 Ω
Force factor (BxL) blank.gif4.2
blank.gifInductance coil (Le) blank.gif0.6 mH
blank.gifCoil diameter blank.gif25 mm
blank.gifCoil support blank.gifAlu
blank.gifLinear Excursion (X MAX)blank.gif± 3 mm
blank.gifTransmitting surface (Sd) blank.gif137 cm2
blank.gifMagnet weight blank.gif10 oz.
blank.gifWeight blank.gif950 g
Speaker TypeMidbass
