DAYTON AUDIO DML25-4 Midrange Speaker Driver
The Dayton Audio DML25-4 is a paper cone midrange speaker, designed according to the DML principle to diffuse sound over a wide area. Its compact square format makes it easy to integrate into low-profile speakers, while its wide dispersion allows greater placement flexibility. It covers a frequency range from 150Hz to 15kHz, with a sensitivity of 82.1dB and a power handling of 20W RMS, up to 40W maximum under 4Ω.
Reference : 22326
26,91 €tax incl.
22,42 € tax excl.
Dayton Audio DML25-4 Midrange Speaker 20W 4 Ohm 82dB 150Hz-15kHz
Photo du DAYTON AUDIO DML25-4 Midrange Speaker 20W 4 Ohm 82dB 150Hz-15kHz
Its rubber surround, polymer basket and neodymium magnet help keep the assembly light and shallow. The DML25-4 can thus be used in soundbars, compact speakers, docking stations or satellite speakers, in sealed as well as ported enclosures.
Dayton Audio DML25-4 features
Technical specifications
Product typeMidrange Speaker
Nominal diameter5.08cm (2")
Impedance4Ω
Sensitivity82.1dB 2.83V/1m
PowerRMS: 20W
MAX: 40W
Frequency response150Hz-15kHz
Voice coil diameter2.49cm (0.98")
Thiele-Small parameters
Resonance frequency (Fs)212Hz
DC resistance (Re)4.3Ω
Voice coil inductance (LE)0.09mH
Mechanical quality coefficient (Qms)3.83
Electromagnetic quality coefficient (Qes)1.5
Total quality coefficient (Qts)1.1
Compliance equivalent volume (Vas)0.0008ft³
Mechanical compliance of suspension (Cms)0.15mm/N
Force factor (BL)3.86T·m
Max linear excursion (Xmax)1.5mm
Cone surface area (Sd)16cm²
Mounting informations
Total external diameter6.68 x 6.68cm (2.63" x 2.63"
Cutout diameter5.94 x 5.94cm (2.34" x 2.34")
Depth2.64cm (1.04")
Number of mounting holes4
Materials
ConePaper
MagnetNeodymium
FramePolymer
SurroundRubber
Weight0.11kg
Package1x Dayton Audio DML25-4
Speaker Power (W RMS)20.0
Speaker TypeMidrange
Impedance (Ω)4
Loudspeaker diameter (mm)50.8
Diaphragm typePaper
Efficiency / Sensitivity (dB)82.1
Max Linear Excursion (Xmax) (mm)1.5
Lowest frequency (Hz)150
Highest frequency (Hz)15000
DAYTON AUDIO DML25-4 Midrange Speaker Driver 20W 4 Ohm 82dB 150Hz-15kHz
The Dayton Audio DML25-4 is a paper cone midrange speaker, designed according to the DML principle to diffuse sound over a wide area. Its compact...
