DAYTON AUDIO MB620-8 Low Midrange Speaker Driver
The Dayton Audio MB620-8 is a professional 6.5" (Ø16.51cm) low midrange speaker driver designed for high-power applications requiring excellent dynamics and high efficiency.
Reference : 22317
44,91 €tax incl.
37,42 € tax excl.
DAYTON AUDIO MB620-8 Low Midrange Speaker Driver 200W 8 Ohm 94dB 100Hz-7000Hz Ø16.51cm
The Dayton Audio MB620-8 is a professional 6.5" (Ø16.51cm) low midrange speaker driver designed for high-power applications requiring excellent dynamics and high efficiency. Compatible with 8Ω loads, it handles 200W RMS continuous power (400W max) and features a sensitivity of 94dB (2.83V/1m) with a frequency response ranging from 100Hz to 7kHz. It incorporates a treated paper cone combined with a pleated cloth surround, a high-temperature 50.8mm (2") voice coil mounted on a fiberglass former, and a powerful vented ferrite motor ensuring excellent power handling and low thermal compression. Its rugged stamped steel frame, vented pole piece, and ±2mm linear excursion contribute to accurate and dynamic sound reproduction, even at high output levels. Thanks to its 104Hz resonant frequency, 6.68 T·m BL factor, and design optimized for professional applications, the MB620-8 is an ideal solution for PA speakers, two-way and three-way systems, stage monitors, high-efficiency DIY loudspeakers, and other audio projects requiring a reliable and high-performance low midrange driver.
DAYTON AUDIO MB620-8: High Efficiency and Excellent Power Handling
With a sensitivity of 94dB and a power rating of 200W RMS, the MB620-8 is capable of delivering high sound pressure levels while maintaining excellent signal control. Its 2" voice coil and vented ferrite motor ensure efficient heat dissipation for demanding applications.
DAYTON AUDIO MB620-8: Design Optimized for Professional Applications
The MB620-8 features a treated paper cone and a pleated cloth surround, offering an excellent balance of rigidity, low mass, and durability. Its stamped steel frame and robust magnetic structure ensure increased reliability in the most demanding professional environments.
DAYTON AUDIO MB620-8: Ideal for PA Speakers and DIY Systems
Thanks to its 100Hz to 7kHz bandwidth, ±2mm linear excursion, and excellent efficiency, the Dayton Audio MB620-8 integrates perfectly into PA loudspeakers, multi-way systems, stage monitors, and DIY projects requiring a low midrange driver capable of reproducing voices and instruments with precision and impact.
Technical Specifications
Product typeWoofer Speaker Driver
Nominal diameterØ16.51cm (6.5")
Power handlingRMS: 200W
Max: 400W
Impedance8Ω
Frequency response100Hz - 7000Hz
Sensitivity94dB 2.83V/1m
Voice coil diameterØ50.8mm (2")
Thiele-Small Parameters
Resonant frequency (Fs)104Hz
DC resistance (Re)5.47Ω
Voice coil inductance (Le)0.93mH
Mechanical Q (Qms)4.26
Electrical Q (Qes)0.69
Total Q (Qts)0.55
Compliance equivalent volume (Vas)0.24ft³
Mechanical compliance of suspension (Cms)0.273mm/N
BL product (BL)6.67T·m
Diaphragm mass including air load (Mms)8.59g
Maximum linear excursion (Xmax)2mm
Cone surface area (Sd)132.2cm²
Materials
Cone materialPaper
Surround materialCloth
Voice coil wire materialCCA
Voice coil former material-
Basket materialSteel
Magnet materialFerrite
Mounting Information
Overall outside diameterØ166.88mm (6.57")
Baffle cutout diameterØ147.32mm (5.8")
DepthØ80.01mm (3.15")
Number of mounting holes4
Bolt circle diameterØ156.21mm (6.15")
Recommended enclosure volume
Sealed enclosure5.66L (0.2ft³)
Sealed F3150Hz
Bass reflex enclosure11.33L (0.4ft³)
Bass reflex F376Hz
Speaker Power (W RMS)200.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)94.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)100
Highest frequency (Hz)7000
DAYTON AUDIO MB620-8 Low-Midrange Speaker Driver 200W 8 Ohm 94dB 100Hz-7000kHz Ø16.5cm
The Dayton Audio MB620-8 is a professional 6.5" (Ø16.51cm) low midrange speaker driver designed for high-power applications...
