DAYTON AUDIO PC83-8 Speaker Driver Full Range 30W 8 Ohm 85.6dB 80Hz-20khz Ø7.6cm
The Dayton Audio PC83-8 is a wide-range loudspeaker using a braided glass fibre membrane, rubber suspension and a powerful motor. It provides low distortion and high dynamics for accurate and dense reproduction over a wide frequency range.
4.9 / 5
Reference : 13950
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 16-06-2026.
Grantie 5 ans
Dayton Audio PA83-8
Speaker Driver Full Range 30W 8 Ohm 85.6dB 80Hz-20kHz Ø7.6cm
Dayton Audio PA83-8 Haut-Parleur Large Bande 30W 8 Ohm 85.6dB 80Hz-20kHz Ø7.6cm
The Dayton Audio PC83-8 is a wide-range loudspeaker using a braided glass fibre membrane, rubber suspension and a powerful motor. The addition of a copper cover on the pole allows better membrane control, lower inductance and reduces distortion for improved high frequency response. Offering very good performance over a wide frequency range, a controlled off-axis response and high efficiency, the restitution is impressive for such a small speaker size.
Speaker driver typeFull range
Nominal diameterØ7.6cm (3")
PowerRMS : 30W
Max : 60W
Impedance8Ω
Frequency response80Hz - 20kHz
Sensibilité85.6dB @ 2.83V/1m
Voice coil diameterØ2.5cm (1")
Thiele-Small Parameters
Resonant frequency (Fs)82.1Hz
DC Resistance (Re)6.8Ω
Voice coil inductance (Le)0.60mH
Mechanical quality coefficient (Qms)3.68
Electromagnetic quality coefficient (Qes)0.76
Total quality coefficient (Qts)0.63
Compliance equivalent volume (Vas)0.06 fr.³
Mechanical compliance of suspension (Cms)1.40mm/N
Force factor (BL)3.5Tm
Diaphragm mass inc. airload (Mms)2.7g
Maximum linear excursion (Xmax)2mm
Surface area of cone (Sd)30.2cm²
Materials
Cone materialPoly Composite
Surround materialRubber
CopperCopper
Voice coil formerKapton / Polyimide
Frame materialSteel
Magnet materialFerrit
Mounting informations
Overall outside dimensions83mm
Baffle cutout diameterØ77.4mm
Depth50mm
Bolt circle diameterØ92.5mm
Number of mounting holes4
Optimum cabinet size (measured with BassBox 6 Pro)
Sealed volume0.09ft³
Sealed F3107Hz
Vented volume0.16ft³
Vented F354Hz
Speaker Power (W RMS)30
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)76.0
Diaphragm typeGlass fiber
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)80
Highest frequency (Hz)20000
7 reviews
Superb performer with digital crossovers!
I bought this because it has no typical breakup of 6.5 inhers.
With digital crossover you can pair this with compression driver at 6000hz and also play as low as 130hz to pair with 15 inch mid bass. That comprises perfect setup for studio monitoring and mastering systems. For normal use such a setup really raises the HIFI experience to other level.
This review has been posted for DAYTON AUDIO PC83-8 Speaker Driver Full Range 30W 8 Ohm 85.6dB 80Hz-20khz Ø7.6cm
Meilleur rapport qualité / prix ?
J'ai d'abord acheté ces haut-parleurs un peu par hasard (les large bande que je voulais n'étais pas dispos, et ceux-ci semblaient intéressants). J'ai calculé de petites enceintes bass reflex en agglo de récupération, ceci avec l'objectif de remplacer les enceintes pourries dont ma fille avait hérité avec une micro chaîne. Elle pensait que c'était une lubie de ma part, mais quand je les ai branchées, elle a juste dit "Ah, d'accord...". L'ensemble n'est pas vraiment de la hifi, mais c'est agréable à écouter, un bon investissement.
Ensuite j'ai lu le commentaire de Kolja Z., que je remercie vivement ! J'ai commandé une deuxième paire de haut-parleurs, et j'ai fabriqué les Needle, en suivant les plans qu'on trouve facilement sur le net. J'ai encore utilisé de l'agglo de 15mmm (la construction était un peu sportive !), et j'ai connecté les baffles à mon ordi avec un DAC et un petit ampli classe D. Le résultat est franchement surprenant, surtout au niveau des graves compte tenu de la taille de ce tout petit haut-parleur. Il a fallu trouver un peu de place au sol, mais le son est agréable et précis avec une gamme étendue. Je sens que je vais me régaler. Ça doit être difficile de faire mieux à ce prix.
Excellent little full range speaker!
Mounted in a 'Cyburgs Needle', a TQWT-enclosure originally conceived and designed with Visaton's FRS 8 in mind, the Dayton PC83-8 quite frankly blows my mind!
It outperforms the FRS 8 in pretty much every discipline. Most notably, providing significantly more low-end, more detail in the highest frequencies and a less harsh upper midrange.
The overall listening experience is pleasant, soundstage, as to be expected from a small full range speaker, is impressive.
Given the price, you get a lot more than you pay for, especially if you pair this little gem with the right enclosure.
Thumbs up!
Très bien en médium aussi
Utilisé comme medium sur de toutes petites enceinte de bureau (sur un système 2.1). J'ai préféré confier le registre aigu à un vrai tweeter (Audax TW025F1) + filtre adapté donc. L'ensemble est très agréable, et convaincant. Très bon rapport qualité / prix pour ce petit HP.
Une petite remarque pour Audiophonics : Mon colis était un peu écrasé (pendant le transport certainement). J'ai pris le risque d'accepter, et pas de bobo, ouf. Svp, ne lésinez pas sur l'emballage de protection, car ces petits désagréments arrivent souvent (quitte a bourrer de papier ou carton recyclé, ça sera toujours mieux pour la planète). En dehors de ça, service parfait comme d'habitude.
très bon resultat
Petits hp large bande fonctionnant très bien sur petite enceinte bluetooth avec juste un petit filtre RC série
The Dayton Audio PC83-8 is a wide-range loudspeaker using a braided glass fibre membrane, rubber suspension and a powerful motor. It provides low...
