Loudspeaker-medium CRB-130PS
Reference : 1295
36,90 €tax incl.
30,75 € tax excl.
Two-coil subwoofers combine a modern finish with optimized materials. Polypropylene membranes are equipped with a special structure, giving better stability to moisture-insensitive materials.
Hi-Fi Built-in Hi-Fi Bass Speakers, 4 Ω, 60 W MAX
Grave-medium and powerful bass, special polypropylene membrane with excellent impulse response, lacquered salad bowl with gold-plated connections, 60-5000 Hz; combines ideally with CARPOWER's complementary high-performance speakers. Mounting dimensions 113 x 58 mm, external dimensions 130 x 130 mm, type 130.
blank.gifImpedance (Z) blank.gif4 Ω
blank.gifResonance frequency (fs) blank.gif75 Hz
blank.gifMaximum bandwidth blank.giff3-5000 Hz
blank.gifMaximum power blank.gif60 WMAX
blank.gifNominal power (P) blank.gif30 WRMS
blank.gifAverage sound pressure (1 W / 1 m) blank.gif88 dB
blank.gifCompliance susp. (Cms) blank.gif0.30 mm / N
blank.gifMovable mass (Mms) blank.gif10 g
blank.gifMechanical overvoltage. (Qms) blank.gif4.26
blank.gif Electrical overvoltage (Qes) blank.gif1.28
blank.gifFact. total overvoltage (Qts) blank.gif0.98
blank.gifVolume equ. (VAS) blank.gif5.5 l
blank.gifDC resistance. (Re) blank.gif3.6 Ω
Force factor (BxL) blank.gif4.0
blank.gifInductance coil (Le) blank.gif0.6 mH
blank.gifCoil diameter blank.gif25 mm
blank.gifCoil support blank.gifAlu
blank.gifLinear Excursion (X MAX)blank.gif+ -2.5 mm
blank.gifTransmitting surface (Sd) blank.gif92 cm 2
blank.gifMagnet weight blank.gif8 oz.
blank.gifWeight blank.gif750 g
Speaker TypeMidbass
