TANG BAND W8-1772 Speaker Driver Full Range 30W 8Ω 95dB Ø22.38cm
Tang Bang's W8-1772 full-range driver offers extensive sound reproduction thanks to its 22.38cm-diameter diaphragm. It has a power handling capacity of 30W, a paper diaphragm and a fabric suspension for optimum performance.
By buying this product you get 34 loyalty points
Reference : 19284
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 23-04-2026.
TANG BAND W8-1772 : Front view
Tang Bang's W8-1772 full-range driver offers extensive sound reproduction thanks to its 22.38cm diameter diaphragm. It has a power handling capacity of 30W, a paper diaphragm and a fabric suspension for optimum performance.
TANG BAND W8-1772 : Dimensions and SPL versus Frequency
Product typeSpeaker
Speaker typeFull Range
Diaphragm materialPaper
Surround materialFabric
Magnetic systemNeodymium
Nominal impedance
DCR impedance6.8Ω
Sensitivity95dB
Frequency response42Hz - 20kHz
Free air resonance42Hz
Voice coil diameter38.5mm
Air gap height10mm
Rated power RMS30W
Max. power60W
Force factor (BL)7.12TM
Moving mass10.11g
Suspension compliance1374 uMN¯¹
Effective piston area0.0022m²
Levc0.009mH
Zo26Ω
Maximum linear peak (X-Max)3mm
Compliance volume (Vas)94.45L
Total quality factor (Qts)0.27
Mechanical quality factor (QMS)1.02
Electrical quality factor (Qes)0.36
External diameterØ223.8mm
Cutout diameter190mm
Depth111mm
Mounting bolt diameterØ211mm
Mounting holes8
Package1x TANG BAND W8-1772
Speaker Power (W RMS)30
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)223.8
Diaphragm typePaper
Efficiency / Sensitivity (dB)95.0
Max Linear Excursion (Xmax) (mm)3.0
Lowest frequency (Hz)42
Highest frequency (Hz)20000
3 reviews
Sav audiophonics
Petit problème à la livraison
SAV audiophonics présent et ma apporter une solution
Vraiment merci
This review has been posted for TANG BAND W8-1772 Speaker Driver Full Range 30W 8Ω 95dB Ø22.38cm
Surprenant
j ai été surpris , quel potentiel,
Avec un circuit Zobel et une ligne de transmission je m attend à de grand moment de music !
Très joli " TANG BAND"
Ce joli petit HP large bande donne envie de l'écouter, sur baffle plan pour le début. Après, je verrai : TQWT, Pavillon Arrière...voire Bass Reflex avec double résonnateur ?
belle finition en tous cas, et du plaisir avec ce Tang Band...
Tang Bang's W8-1772 full-range driver offers extensive sound reproduction thanks to its 22.38cm-diameter diaphragm. It has a power handling...
