XDUOO XD05 BASIC2 Portable Headphone Amplifier DAC
The xDuoo XD05 Basic2 is a portable DAC and headphone amplifier designed to handle both digital-to-analog conversion and signal amplification. It supports PCM streams up to 32bit / 384kHz, DSD256 as well as MQA 8x, relying on an architecture built around a CS43131 converter in order to reduce distortion to 0.0006% while increasing the signal-to-noise ratio to 124dB, resulting in a cleaner signal and more stable playback.
Reference : 22034
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 10-11-2026.
xDuoo XD05 Basic2 Portable Headphone Amplifier DAC CS43131 Bluetooth 5.4 aptX HD LDAC 32bit 384kHz DSD256
Thumbnail of the xDuoo XD05 Basic2
The xDuoo XD05 Basic2 is a portable DAC and headphone amplifier designed to handle both digital-to-analog conversion and signal amplification. It supports PCM streams up to 32bit 384kHz, DSD256 as well as MQA 8x, relying on an architecture built around a CS43131 converter in order to reduce distortion to 0.0006% while increasing the signal-to-noise ratio to 124dB, resulting in a cleaner signal and more stable playback.
Designed for both portable and desktop use, it combines USB-C and Bluetooth 5.4 connectivity, allowing integration with a wide range of sources while maintaining compatibility with high-definition codecs, while its 750mW output power enables it to drive headphones with varying sensitivities. This approach extends to a gain adjustment and a 99-step volume control, enabling precise listening level tuning, while maintaining consistent operation through a switchable power supply between battery and DC mode, facilitating seamless use both on the move and in a fixed setup.
xDuoo XD05 Basic2: High-Quality Digital Decoding & Amplification
The XD05 Basic2 integrates DAC functionality in order to ensure compatibility with a wide range of devices, including smartphones, enabling high-quality audio reproduction. To achieve this, it supports decoding up to PCM 32bit 384kHz, DSD256 and MQA 8x.
Performance is supported by a CS43131 DAC chip, enabling a THD of 0.0006% and a signal-to-noise ratio of 124dB, resulting in a signal with minimized distortion and noise. In addition, the XD05 Basic2 allows easy replacement of its operational amplifier chip.
Image showing the DAC chip of the xDuoo XD05 Basic2
Image showing the Bluetooth chip of the xDuoo XD05 Basic2
xDuoo XD05 Basic2: Connectivity and Architecture
Designed for portability, the XD05 Basic2 delivers an output power of 750mW through its 6.35mm jack output. Audio sources can be connected via its USB-C input or Bluetooth 5.4 connection. The Bluetooth interface supports formats such as LC3, aptX, aptX HD, aptX Adaptive, aptX Lossless and LDAC.
Alongside its outputs, it integrates gain adjustment to match different headphone types, as well as a 99-step volume control for precise level management. On the power side, the XD05 Basic2 offers both DC and battery modes, allowing adaptation between mobile use and desktop operation.
Technical Specifications
Product typePortable DAC and headphone amplifier
DAC chipCS43131
Inputs1x USB-C
Bluetooth 5.4
Outputs1x 6.35mm jack
1x 3.5mm jack AUX out
SNR124dB
Frequency responseUSB / BT: 20Hz-20kHz (±0.5dB)
AMP: 10Hz-80kHz (±0.5dB)
THD+NUSB / BT: 0.0006% @ 1kHz
AUX OUT: 0.0003% @ 1kHz
Output power750mW @ 32Ω
CrosstalkUSB / BT: ≥74dB
AUX OUT: ≥107dB
Charging timeFast charge: ≤ 3h
Slow charge: ≤ 5h
Playback timeUSB: 11h
Bluetooth: 15h
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
MQA 8x
CompatibilityWindows
Linux
Mac OS X
iOS
Android
Supported Bluetooth codecsLE Audio: LC3 / aptx_Lite / aptx_AD
Classic Audio: SBC, AAC, aptX, aptX_HD, aptX_Adaptive (aptX_Low Latency, aptX_High Quality, aptX_Lossless), LDAC
Gain0/+6dB
Dimensions139 x 75 x 23mm
Chassis materialAluminum
Weight0.3kg
Package contents1x xDuoo XD05 Basic2
1x USB-C cable
1x USB-C OTG cable
1x 6.35mm to 3.5mm adapter
1x Rubber feet
OutputJack 6.35mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ClassClass A / AB
XDUOO XD05 BASIC2 Portable Headphone Amplifier DAC CS43131 Bluetooth 5.4 aptX HD LDAC 32bit 384kHz DSD256
The xDuoo XD05 Basic2 is a portable DAC and headphone amplifier designed to handle both digital-to-analog conversion and signal amplification. It...
