Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling wires. The SOST Solid Core Silver Wire series allows the manufacture of single-stranded cables made of the highest quality UP-OCC pure silver with a high level of PTFE dielectric insulation.
You can now design cables in pure silver at home and set the standard for high-end audio cables. The process developed by Professor Ohno of the Chiba Institute of Technology of Japan raises the purity of the silver strand to 99.99998%, well above the level of standard cables.
The oxygen particles inside the silver strand are thus reduced to an insignificant level, ensuring a high level of stability over time and preventing oxidation over the long term.
Neotech SOST UP-OCC solder cables are available in various diameters and cross-sections, thus meeting all the expectations of informed amateurs wishing to design their own HiFi cables.
| Specifications | |
| Product type | Wiring cable |
| Conductor | Solid pure UP-OCC silver (purity = 99.99998%) |
| Section | 0.82mm² (18AWG) |
| Insulation | PTFE |
| Conductor diameter | Ø1mm |
| External diameter | Ø2mm |
| Rated voltage / current | 300V / 3A |
| Color | Blue |
| Quantity | Cable sold by the meter |
| Diameter (mm) | 2.0 |
| Length (m) | Sold by length |
| Number of conductors | 1 |
| Insulation material | PTFE |
| Shielding | No |
| Section (mm²) | 0.823 |
| Conductors material (Cable) | Silver |
| Conductors Plating (Cable) | None |
| Ground / Shielding | No |
