VIABLUE M1 SILVER Grounding Wire 0.5mm²
The Viablue M1 Silver is a cable sold by the meter designed for making grounding connections for turntables and phono systems. As the single ground conductor of the NF-S5 cable, it uses silver-plated OFC strands with a cross-section of 0.5 mm², in order to ensure a low-resistance connection between the turntable and the ground terminal of the phono preamplifier. The strands are protected by polyethylene insulation, a material with low electrostatic charge that limits interference on the connection and preserves the transmission of high-frequency components.
Reference : 22336
5,60 €tax incl.
4,67 € tax excl.
Câble vendu au mètre
VIABLUE M1 SILVER Silver-Plated Copper Grounding Wire 0.5mm² Ø9mm
VIABLUE M1 SILVER: Front view
Technical specifications
Product typeGrounding wire
Cross-section0.5mm²
Conductor materialSilver-plated OFC copper
InsulationPolyethylene
Outer diameterØ9mm
PackageSold by the meter
Diameter (mm)9.0
Number of conductors1
Insulation materialPE
ShieldingNo
Max cable diameter (mm)N/A
Mounting typeN/A
ConnecticN/A
Section (mm²)0.50
Contacts numberN/A
Max panel thickness (mm)N/A
ConnectorN/A
Contacts Plating (Connector)N/A
Ground / ShieldingNo
VIABLUE M1 SILVER Grounding Wire Silver Plated Copper 0.5mm²
The Viablue M1 Silver is a cable sold by the meter designed for making grounding connections for turntables and phono systems. As the single ground...
