MUNDORF ACW205P-BK/BU ANGELIQUE Single-Strand Copper Wiring Cables 2x0.1963mm² Black/Blue
New
The MUNDORF ACW205P-BK/BU ANGELIQUE is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 0.5mm diameter conductors, with a cross-section of 2x 0.1963mm².
Reference : 22538
5,99 €tax incl.
4,99 € tax excl.
Cable sold by the meter
Mundorf ACW205P-BK/BU ANGELIQUE Single-Strand Copper Wiring Cables 2x0.1963mm² Black/Blue
The MUNDORF ACW205P-BK/BU ANGELIQUE is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of 0.5mm diameter conductors, with a cross-section of 2x 0.1963mm². Featuring YI8 PVC insulation and black / blue identification, it is intended in particular for the internal wiring of loudspeakers and electronic equipment, as well as for various audio cable constructions. Its DC resistance of 2x 87 mΩ/m and its outer diameter of 2x 0.9mm make it a suitable solution for applications requiring a SolidCore conductor with a large cross-section. The cable is rated for a nominal voltage of 100V DC and an operating temperature range between -20°C and +90°C.
Technical Specifications
Product TypeWiring cable
Conductor MaterialCopper
Conductor Diameter2x 0.5mm
Cross-Section2x 0.1963mm²
DC Resistance2x 87mOhm/m
Outer Diameter2x 0.9mm
Nominal Voltage100V DC
Operating Temperature-20°C / +90°C
ColorBlack / Blue
PackagingSold by the meter
Diameter (mm)0.5
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)0.196
Ground / ShieldingNo
MUNDORF ACW205P-BK/BU ANGELIQUE Single Strand Copper Wiring Cable 2x0.1963mm² Black / Blue
The MUNDORF ACW205P-BK/BU ANGELIQUE is a SolidCore audio wiring cable made of Angelique® copper, offered as a twisted pair of...
