MUNDORF MRESIST SUPREME MRES20-6.8 Resistor 20W 6.8 Ohm
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
Reference : 4073
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 03-11-2026.
Mundorf MResist SUPREME MRES20-6.8
Mundorf resistor MRES20-6.8
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution. This type of resistance allow finer details and a much better spatialization.
The structure of this resistance is composed of two wires 1Ω wound around a heat-resistant cement, this design stabilizes the inductance and maintains its value under 75µH.
Moreover, the resistors of the MResist SUPREME range are very useful for electronic systems designed for a deep neutrality in the sound reproduction. Thanks to a fire-resistant special molding compound, the resistance winding is stable and maintained in its optimal position, thus preventing the circuit from microphonic effects.
Finally, to guarantee a high quality sound even with heavy loads, a special Copper/Nickel alloy is applied as conductor with a positive and extremely low temperature coefficient of 50ppm/°C.
Resistance6.8 ±2%
Power20W
Body dimensions of the resistance51 x ⌀ 14.4mm
Wires dimensions40 x ⌀ 1mm
Resistance (Ohm)6.8
Tolerance (%)2
Power (W)20.0
Très bonne résistance
Utilisée en L PAD pour atténuation après montage d’un premier filtre, je n’ai pas constaté de dénaturation du signal.
Très bonne résistance pour le passage du signal et vu le prix, cela serait dommage de s’en priver
This review has been posted for MUNDORF MRESIST SUPREME MRES20-6.8 Resistor 20W 6.8 Ohm
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these...
