Pack AUDIOPHONICS RASPTOUCH AMP 9023 + Q ACOUSTICS 3010i + OFC Speaker Cable 2x2m
Pack AUDIOPHONICS RaspTouch Amp 9023 + Q Acoustics 3010 + OFC HP Cable 2x2m
By buying this product you get 59 loyalty points
Reference : 12103
599,00 €tax incl.
499,17 € tax excl.
Instead of 649,70 €
Shipping from France
Billing in France
Technical support in France
Pack content
PACK RaspTouch Amp 9023 + Q Acoustics 3010i + Câble HP MEDIA-SUN
Amplifier / DAC / Streamer + Black Q Acoustics 3010i Speakers + MEDIA-SUN MS2 2x2m Speaker Cable
With this pack you have a high quality, ready-to-use audio system. All you have to do is plug it in and you can enjoy your audio library and incredible sound reproduction in an instant.
Rasptouch AMP ES9023
The RaspTouch Amp is an all-in-one version of the RaspTouch. Indeed, this network reader embeds both a DAC ES9023 supporting sampling rates up to 24bit 192kHz and a TPA3118 Class D amplifier of 2x30W. A coherent system that will allow you to supply your Q Acoustics speakers with a clean signal for a stunning performance.
In addition, since the Rasptouch Amp is a network drive using a Raspberry Pi 3 B+, it will allow you to simply enjoy your music, whether it is stored locally or on a server. In this version it comes with a Max2Play operating system license, offering an intuitive and ergonomic interface to navigate within your audio library and enjoy it without limits.
The Q Acoustics 3010i speakers provide surprising sound performance and excellent sound reproduction, including a very well restored low end of the spectrum. With very good levels of distortion, the Q Acoustics 3010i prove to be versatile companions who will be able to accompany you during a long listening session or in front of a movie. The speakers are offered here in their Graphite Black version, offering a sober and elegant design that will fit perfectly into most interiors.
MEDIA-SUN MS2 Cuivre OFC 2x2m Speaker cable
These high quality speaker cables are made of OFC copper conductors to ensure optimal conductivity. They will be able to transport your audio signal efficiently to ensure good audio output.
Rasptouch AMP 9023
DACES9023
AmplifierTPA3118 Class D
Power2x30W
OSMax2Play
Samplinf rate24bit 192kHz
Inputs4x USB-A
1x Ethernet RJ45
1x Micro SD slot
Outputs1x RCA Stéréo
1x HDMI
Screen7" Touchscreen
HousingAluminium
Q Acoustics 3310
Case typeReflex 2 voices
Bass loudspeaker diameter100mm
Treble loudspeaker diameter22mm
Frequency response65Hz - 30kHz
Nominal impedance6 Ohm
Minimal impedance4 Ohm
Sensitivity86dB
Recommanded power15-75W
Transition frequency2.6kHz
Dimensions150 x 253 x 252mm
Weight4.1kg / speaker
ColorGraphite black
Media Sun MS2
Length2x2m
Section2x2.5mm²
InsulationPVC
ConductorCopper 125 strands, 0.15mm (0.02mm²)
Cable thickness6.8x3.5mm
ColorWhite
ManufacturingGermany
