ARYLIC S50 PRO Lecteur Réseau Multiroom WiFi Bluetooth Apt-X HD DAC ES9023 ADC AK5720
The S50 Pro from Arylic is a concentrate of functionalities that will allow you to realize a complex audio installation at an affordable price.
4.0 / 5
Reference : 14459
199,00 €tax incl.
165,83 € tax excl.
This product has been replaced by the new version, the ARYLIC S50 PRO+.
Arylic S50 PRO
Multiroom network drive, ES9023 DAC, ADC AK5720, preamplifier, re-streamer
Arylic's S50 Pro is a network drive with a tremendous lot of features that you will help you achieve a complex audio system at an affordable price.
This network player with DAC and preamplifier has two analog inputs and its own ADC circuit. It then belongs to the very few multiroom streamers capable of performing restreaming from an analog source. The S50 Pro can connect to a turntable, cassette, reel-to-reel player or any other pure-analog source, convert the audio stream and manipulate it like any digital stream (injecting in its multiroom circuit while using its integrated equalizer).
Traditional features are not left out since the S50 Pro supports among the best protocols regarding connectivity.
- Bluetooth 5.0 with 30m range, apt-X HD & apt-X low latency (for home theater & gaming platforms without latency).
- LAN (RJ45) and WIFI for a full network connectivity.
- Protocols Airplay streaming, Spotify Connect, Qplay, DLNA, UPnP.
- USB to read audio files stored on mobile media on the fly.
Arylic S50 Pro Arylic S50 Pro
DAC ESS9023 & ADC AK5720
In addition to its multi-room capabilities and its many inputs, the S50 Pro features a high-quality digital to analog conversion circuit. This DAC is based on the famous ES9023 SABRE chip, with 24bit 192Khz sampling rate and Hyperstream technology to overcome the usual shortcomings of conventional Delta Sigma DAC. The result is immediately tangible, with a feeling, a sound accuracy competing Delta Sigma technology. This chip allows the S50 Pro to offer a very comfortable signal / noise ratio of 110dB on its analog output.
The acquisition of the analog signal uses a AKM5720 chip. It can grant a 96kHz /24-bit with a 102dB signal to noise ratio..
4Stream dedicated APP
The S50 Pro is compatible with the 4STREAM app (Android & IOS). The latter is used to group all the control functions (volume, EQ), playback (track selection, play / pause, connection to an online streaming service). It also controls all function relative to live stream (direct sending an audio file from the onboard memory of the phone / tablet on which the app is installed).
Many services are supported starting with AirPlay, DLNA, Spotify Connect, UPNP, internet radio and especially a complete multiroom management.
Finally, the application enables the S50 Pro to connect to Spotify resources, Tidal, Qobuz, iHeartRadio, TuneIn, QQ Music, Napster to access all your onlines library and services.
Remote included
In addition to control via the application, the S50 Pro comes with its own remote to allow easy control over the essential features.
The user can use this remote to adjust the volume device, to set / unset the mute parameter, to change the signal path (USB, Line Input, Bluetooth, WiFi), and even configure the software equalizer.
Two line inputs & SPDIF output
The S50PRO can easily join an existing audio system in order to add some or all of its own features. For this purpose, it uses an SPDIF output circuit (coaxial & optical) which allows it to attack an external DAC at a sampling frequency of 48kHz / 16bit.
The selection of active output (preamp output, SPDIF, syncronisation multiroom) can be easily achieved with the remote control or through a smartphone / tablet equipped with the appropriate application. It is therefore possible to leave all connections in place and alternate between each configuration depending on the situation.
TypeNetwork Drive
DAC
Preamplifier
InputsWi-Fi IEEE802.11 b / g / n 2.4G
LAN RJ45 10 / 100m
Bluetooth 5.0
(USB storage file)
2x RCA Stereo (analog)
OutputsCoaxial
Optical
RCA Stereo (analog)
Power supply5V-1A Micro USB
DecodingUp to 24bit / 192kHz
formats supportedFLAC / MP3 / AAC / AAC + / ALAC / APE / WAV
Frequency response20Hz-20kHz
SNR110dB
THD0.03%
Remote controlProvided
Dimensions120 x 113 x 37mm
Weight0.4kg
Package contents
Arylic S50Prox1
Stereo RCA to RCA Stereo Cablex1
RCA stereo to 3.5mm stereox1
AC adapter & cablex1
Antenna x2
Remote controlx1
InputRJ45
InputWiFi
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9023
Max sampling rate192kHz
ColorSilver
2 reviews
Préampli et lecteur réseau intéressant mais perfectible.
Déballage : belle présentation, discret, télécommande même format que alientek d8 auquel il est branché. Petite alimentation. ecran sobre et dimmable.
veille reglable.
on aurait aimé un cable optique ou coaxial.
installation : après allumage il faut se connecter par wifi à l'appareil depuis l'application 4stream, en selectionnant sur le telephone le reseau du s50, bien penser à accorder droits à 4stream pour tout et permettre la connexion même sans acces internet. Si cela bloque, changer de telephone (mon 1er ne me demandait pas assez vite les droits à accorder ou blocage). Ensuite 4 stream vous demandera le mot de passe du routeur ou box wifi pour s'y connecter. Le lecteur reseau me propose de telecharger et d'installer un update, c'est fait en 2 minutes.
essai 1 : le nas, ici c'est juste un disque ssd sur mon routeur netgear, partage smb ou dlna. Parfait, acces sans aucune coupure, tous les fichiers visibles, navigation par dossier. les pochettes sont visibles sur le telephone avec 4stream (qui est connecté au routeur maintenant), sur l'appareil on a le titre et l'artiste, un peu comme l'afficheur d'un lecteur rasptouch. 4stream permet la navigation, le volume, les favoris (12) d'accès rapide.
sortie optique, rca ou coaxiale essayé vers l'alientek. très léger souffle, c'est l'ampli. Je vais l'utiliser en optical out.
treble et bass seulement, pas de balance, lecteur non gapless.
Pas d'accès à grand chose comme parametres, la possibilité de changer de nom multiroom. pas d'egaliseur.
Qualité sonore c'est très bien après quelques morceaux, il faut surtout eviter de toucher de trop aux sources, sinon coupe, pareil pas trop toucher aux menus de 4stream, si on commence à vouloir naviguer sur d'autres sources musicales, celle jouée va se couper. Il y a un léger bip quand on aumente ou baisse le volume par la telecommande, choix discutable non modifiable.
essai 2 clef usb : le site arylic le previent c'est pas le point fort, en effet, s'il va reconnaitre une clef de 256go il n'a scanné que 889 morceaux de la clef, c'est 1000 max. ils sont rangés par navigation de dossier depuis 4 stream, le son depuis la clef est moyen, certains morceaux sont manquants en fonction de leur codec et qqfois cela saute. Pas de pochettes lues par clef. Egalement quand on branche une clef la lecture en cours se coupe.
essai 3 : bluetooth, c'est bluetooth entrant, par exemple pour l'acces du xduoo XIII, touche bluetooth de la telecommande puis appairage classique. nickel, pas de transmission vers un casque du s50+.
il me reste encore à essayer de brancher par exemple un lecteur cd pour voir sur aux in ou optical in.
essai radio : depuis 4stream recherche de france inter dans netradio, on peut lire les rubriques. marche très bien.
essai lecture des fichiers audio presents sur le smarphone par 4stream, pas de souci particulier, on peut lire sans appairer par bluetooth.
essai service en ligne type spotify ou autre, je n'ai pas de services payants cela devrait marcher sans probleme.
Au final lors de ce 1er branchement, plusieurs heures qu'il tourne, sans chauffer, il est agreable, j'aime la telecommande, l'ecran qui diffuse le morceau, le son est très bon. Aucune coupure en wifi depuis le routeur. Apres des tentatives de lecteur rasperry pi avec moode et runeaudio qui ne voyait pas mon dlna , je suis satisfait de cette partie.
j'aurai aimé avoir un selecteur de source defilant avec choix de la source en 2 fois, ici si on branche une clef usb, si on connecte un cable ou si on change sur 4stream de rubrique la lecture en cours se coupe brutalement. On peut alors difficilement le conseiller à des gens trop exigeant, et aussi le manque du gapless. c'est le gros point noir du tableau.
Drole de choix ce port usb pour clef qui n'accepte pas les disques et qui sert à rien au final, sauf a depanner si quelqu'un vient avec quelques fichiers car vaut mieux connecter un telephone par le bt à ce moment là. on aurait preferé une entre asynchrone pour un pc.
il manque cruellement plus de personalisation de l'appareil, ainsi choix du bip telecommande, un acces par navigateur en http (à venir peut etre d'apres le site ? oui car l'appareil a une ip, non fixe pour l'instant mais n'importe quel routeur peut fixer l'ip en fonction de son adresse mac. On a un egaliseur trop pauvre.
on a quand meme la mise en veille reglable, ainsi qu'une fonction reveil pas essayé encore.
pour un bricoleur avec de multiples sources, possedant plusieurs ampli fda ou classe ab analogique, des sources numerisées ou analogiques, c'est quand même un outil perfectible mais intéressant.
This review has been posted for ARYLIC S50 PRO Lecteur Réseau Multiroom WiFi Bluetooth Apt-X HD DAC ES9023 ADC AK5720
Préampli et lecteur réseau intéressant perfectible.
veille reglable.
pour un bricoleur de muliples sources, essai, possedant plusieurs ampli fda ou classe ab analogique, des ources numerisées ou analogiques, c'est quand même un outil perfectible mais intéressant.
