DENAFRIPS ARCE Network Player Digital Transport Black
The Denafrips ARCE is a digital transport network player that prioritizes sound quality above all else. This remarkable device supports Roon Bridge, HQPlayer NAA, AirPlay, and DLNA, meeting the needs of audiophiles looking for a variety of playback options.
By buying this product you get 119 loyalty points
Reference : 21418
1 190,00 €tax incl.
991,67 € tax excl.
Denafrips Arce Network Player Digital Transport Roon Bridge HQPlayer NAA Airplay DLNA 32bit 384kHz DSD256 Black
Photo of the Denafrips ARCE
The Denafrips Arce is a digital transport network player that prioritizes sound quality above all else. This remarkable device supports Roon Bridge, HQPlayer NAA, AirPlay, and DLNA, meeting the needs of audiophiles looking for a variety of playback options. It also offers smooth playback of local files via USB, SD card, and NAS, allowing users to effortlessly enjoy their music library. The network connection is made via the RJ45 Ethernet port, while the signal output can be made via numerous digital ports: AES/EBU, coaxial, Toslink optical, or I2S LVDS via HDMI. Other connectors allow you to connect an external clock or play local files via USB Host or TF card slot. The Arce is capable of delivering up to PCM 32bit 384kHz and DSD256 via its I2S output, providing ultra-high-resolution streaming to the DAC in your Hi-Fi system.
The Denafrips Arce is not autonomous in network playback (it cannot directly access streaming services) and requires the use of a third-party application (such as BubbleUPnP, Mconnect, Roon, or Audirvana, for example) for music control and playback.
Denafrips Arce's architecture
The architecture of the Denafrips Arce
Streamer
Proprietary streamer module developed by Denafrips with AMR Cortex quad-core processor and high-quality quartz oscillator.
AC power input
Deliberate design to eliminate the EMI filter for sound quality adjustment exclusive to new Denafrips products.
O-CORE Transformer
O-Core 60VA shielded transformer, manufactured in-house by Denafrips using high-purity copper.
TCXO clock
Temperature-compensated crystal oscillators for digital signal processing.
DSP
Benefits from Denafrips' years of experience in digital signal processing, integrated into an FPGA chip. Galvanic isolation via optocoupler.
Capacitors
OEM electrolytic capacitors compliant with Denafrips specifications. High-bias linear power regulator.
The Denafrips Arce's connectivity
1I2S output via HDMI LVDS
2Toslink optical output
3Coaxial output
4AES/EBU output
5External clock inputs 49.152M/45.1584M
6TF card slot
7RJ45 Ethernet port
82x USB Host Port
9AC power input
Examples of Denafrips Arce connections
Product typeNetwork player
Digital transport
EthernetRJ45
InputsEthernet
TF card slot
2x USB Host ports
Outputs1x I2S via HDMI LVDS
1x Toslink Optical
1x Coaxial
1x AES/EU Output
Supported sample ratesOptical Toslink, coaxial, AES/EBU outputs: PCM up to 24bit 192kHz, DSD DoP64
I2S output via HDMI: PCM up to 32bit 384kHz, DSD DoP64, DSD up to DSD256
Supported streaming protocolsRoon Bridge, HQPlayer NAA, Airplay (16/44.1kHz), DLNA (16/44.1kHz)
Power supplyAC115V/60Hz, AC230V/50Hz
Energie consumption≤ 20W
Dimensions215 x 230 x 45mm
Weight3.5kg
Package1x Denafrips Arce
1x Remote
InputMicro SD
InputRJ45
OutputAES/EBU
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
DAC / ADC ChipNC
Max sampling rateDSD256
Max sampling rate384kHz
Streaming services & Network protocolsHQPlayer NAA
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
DENAFRIPS ARCE Network Player Digital Transport Roon Bridge HQPlayer NAA Airplay DLNA 32bit 384kHz DSD256 Black
The Denafrips ARCE is a digital transport network player that prioritizes sound quality above all else. This remarkable device supports Roon...
