EVERSOLO T10 Streamer Digital Transport
The Eversolo T10 is a network digital transport designed to handle the routing and management of high-resolution audio streams within a Hi-Fi system, relying on a hardware and software architecture oriented towards signal stability and precision. It delivers extended processing capability up to PCM 32-bit / 768 kHz and DSD512, integrating an OCXO clock paired with a linear power supply to maintain rigorous synchronisation and limit disturbances affecting the integrity of the digital stream.
By buying this product you get 219 loyalty points
Reference : 22073
2 190,00 €tax incl.
1 825,00 € tax excl.
Shipping date: 11-11-2026.
Eversolo T10 Streamer Digital Transport WiFi 6 DLNA UPnP Roon Ready Bluetooth 32bit 768kHz DSD512
Eversolo T10 : Front view
Designed for demanding installations, it combines processing power, advanced network connectivity and local library management, allowing sources — streaming, internal or network storage — to be centralised within a unified interface. This approach enables it to serve as the core of a digital system, while maintaining bit-perfect output and seamless integration with external DACs and evolving audio environments.
Eversolo T10 :Key features
Eversolo T10 : Refined Ergonomics and Design
The Eversolo T10 adopts a CNC-machined aluminium chassis measuring 365 × 310 × 88 mm, whose structural rigidity limits mechanical vibrations liable to interact with sensitive circuits, while ensuring uniform thermal dissipation without active cooling. This approach extends to the integration of an 8.6-inch touchscreen, whose redesigned interface streamlines navigation and reduces access latency when browsing libraries or streaming services.
Eversolo T10 : touchscreen
Eversolo T10 : internal clock
Eversolo T10 : Audiophile Architecture
The power supply relies on a linear toroidal transformer, whose low electromagnetic radiation stabilises the digital stages by limiting parasitic interference, while this energy foundation is complemented by an OCXO clock with PLL optimisation to reduce output jitter. Beyond this internal regulation, the integration of a 10 MHz external master clock input (50/75 Ω) allows synchronisation with external clocks, this approach being further extended by physical separation of the internal sections — power supply, processing, outputs — to contain crosstalk and preserve digital signal integrity throughout the chain.
Eversolo T10 : State-of-the-Art Processing
The T10 integrates an 8-core ARM processor paired with 8 GB of DDR5 RAM, enabling simultaneous execution of streaming services, audio processing and the user interface without resource saturation, while 64 GB of internal eMMC storage ensures fast access to the system and applications. This hardware architecture guarantees smooth navigation through large libraries, while maintaining consistent stability during stream or resolution changes.
Eversolo T10 : CPU
Eversolo T10 : Internal Storage up to 16TB
This processing power translates into the ability to handle high-resolution audio streams continuously via streaming, without perceptible buffering, even in demanding network environments. For those with a local library, the device supports the addition of two SSDs of up to 8 TB each, bringing total capacity to 16 TB, while support for an external CD drive enables disc extraction and direct playback.
Please note: SSDs are not included with the T10
Eversolo T10 : Extensive Compatibility
The EOS audio engine bypasses SRC processing, ensuring reproduction that respects the native resolution of files, while this approach is accompanied by broad support for high-resolution formats (DSD, PCM, FLAC, APE, WAV) with processing capability reaching PCM 32-bit / 768 kHz and DSD512. This versatility extends to native integration of the major streaming services (TIDAL, Qobuz, HIGHRESAUDIO, IDAGIO, Amazon Music, TuneIn Radio, Presto Music, KKBOX, Radio Paradise, Deezer) as well as compatibility with protocols such as Qobuz Connect, Spotify Connect, TIDAL Connect, JPLAY Certified, NAA and DLNA, enabling direct interaction with a variety of software environments. In addition, playback of remote libraries via SMB, NFS or WebDAV extends integration to domestic network infrastructures, ensuring uninterrupted access to content.
Eversolo T10 : EOS
Eversolo T10 : Remote control
Eversolo T10 : Remote Control
Designed to integrate into remotely operated systems, the T10 relies on the Eversolo Control application, enabling full management of playback, libraries and settings from a smartphone or tablet, while the included remote control — compatible with both Bluetooth and infrared — ensures direct control independently of the network.
Eversolo T10 : Signal Processing
The Eversolo T10 integrates a DSP, enabling precise signal equalisation via a multi-band structure of up to 40 bands, allowing fine adjustment of the frequency response according to the system and listening conditions. This approach extends to support for FIR filters, enabling simultaneous control of amplitude and phase, while complementary functions such as physiological compensation (loudness) and dynamic compression allow the output to be adapted for low-level listening or high-dynamic-range content, ensuring consistent reproduction across varied contexts.
Eversolo T10 : 40-band EQ
Eversolo T10 : Evotune
Beyond internal processing, the T10 is compatible with the Evotune system, enabling acoustic room calibration. This approach allows room-specific corrections to be applied — addressing resonances, reflections or speaker positioning — while keeping the digital transport dedicated to its core role of signal routing.
Eversolo T10 : 8 I2S Output Modes
The I2S output via HDMI offers 8 different output modes, ensuring compatibility with the majority of DACs available on the market.
Eversolo T10 : I2S Pinout
Product typeNetwork transport
Inputs1x RJ45 Ethernet port
1x SFP Ethernet port
2x USB-A 3.0 OTG input
2x BNC clock input (50/75Ω)
WiFi
Outputs1x Isolated USB-A output
1x HDMI I2S output
1x Optical Toslink output
1x Coaxial output
1x AES/EBU output
Other connectivityTrigger input
Trigger output
Supported sampling ratesPCM 32bit 768kHz
DSD512
Supported audio formatsDSD (DSF, DFF, SACD ISO Support DST up to DSD512), MP3, APE, WAV, FLAC, AIF, AIFF, AAC, NRG, CUE
WiFiWi-Fi 6 (2.4G+5G dual band)
SFP optical networkSFP modules are not included. Supports single-fibre single-mode, dual-fibre single-mode optical modules and SFP network communication modules.
Streaming servicesSpotify Connect Lossless, TIDAL Connect, Qobuz Connect, DLNA
Supported network protocolsUPnP, NAS, SMB
Display8.6" LCD touchscreen
Internal memory8GB DDR5 + 64GB eMMC
Memory expansionDual SSD bay up to 16 TB (2 x 8 TB)
Power supplyAC 110–240V, 50/60Hz
Power consumption20W
Dimensions365 mm x 310 mm x 88mm
Weight6.3kg
ColourBlack
Package contents1x Eversolo T10
1x Remote control
1x Mains power cable
InputWiFi
InputSFP
InputRJ45
InputClock (BNC)
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputOptical Toslink
OutputCoaxial SPDIF
OutputUSB
DAC / ADC ChipNC
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsTidal Connect
EVERSOLO T10 Streamer Digital Transport WiFi 6 DLNA UPnP Roon Ready Bluetooth 32bit 768kHz DSD512
The Eversolo T10 is a network digital transport designed to handle the routing and management of high-resolution audio streams within a Hi-Fi...
