EVERSOLO DMP-A8 GEN 2 Network Player DAC
Second generation of the DMP-A8, the network player EVERSOLO DMP-A8 GEN 2 retains the same technical foundation with its AK4191EQ + AK4499EX conversion architecture, while benefiting from significant improvements to the hardware platform, interface, network and audio processing.
By buying this product you get 199 loyalty points
Reference : 22494
1 990,00 €tax incl.
1 658,33 € tax excl.
Shipping date: 13-11-2026.
EVERSOLO DMP-A8 GEN 2 AK4499EX AK4191EQ XMOS XU316 WiFi DLNA AirPlay Roon Ready Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Network Player
This audiophile network player combines streamer, DAC and balanced analog preamplifier functions, with Hi-Res playback up to 32-bit / 768 kHz PCM and DSD512. It features a large 8.6-inch color touchscreen, 8 GB DDR5 + 64 GB eMMC memory, an M.2 NVMe SSD slot supporting up to 8 TB, as well as network connectivity including Gigabit Ethernet, Wi-Fi 6 and SFP.
Its very comprehensive connectivity includes USB-B, optical, coaxial, HDMI ARC/eARC, RCA and XLR inputs, as well as RCA, XLR, USB-A, optical, coaxial, HDMI I²S, AES/EBU and Subwoofer outputs.
The DMP-A8 Gen 2 also supports numerous streaming services and protocols, AirPlay, DLNA, Roon Ready, Spotify Connect Lossless, TIDAL Connect and Qobuz Connect, etc.
EVERSOLO DMP-A8 GEN 2: AK4191EQ + AK4499EX DAC and AuralEngine
The DMP-A8 Gen 2 retains the conversion architecture of its predecessor with an AK4191EQ digital modulator paired with an AK4499EX DAC, separating digital and analog processing. This section supports PCM streams up to 32-bit / 768 kHz and DSD512, with two ultra-low phase-noise oscillators designed to limit jitter. The new proprietary EverSolo AuralEngine platform adds asynchronous digital processing combined with a high-performance DSP, while maintaining bit-perfect transmission depending on the modes used. The output stages use OPA1612 operational amplifiers.
EVERSOLO DMP-A8 GEN 2 : DAC AK4191EQ + AK4499EX et AuralEngine
EVERSOLO DMP-A8 GEN 2: Balanced R2R Analog Preamplification
The DMP-A8 Gen 2 integrates a fully balanced analog preamplifier with R2R volume control based on precision resistors and relays. It can therefore be directly connected to a power amplifier or active speakers. The XLR analog outputs deliver 4.2V, while the RCA outputs deliver 2.1V. The specified performance reaches a signal-to-noise ratio and dynamic range of more than 129dB in XLR and 127dB in RCA, with a THD+N of 0.000075% in XLR and 0.000086% in RCA. The frequency response extends from 20Hz to 20kHz (±0,.25dB). The outputs can also be configured to fixed level to use the device solely as a network player and DAC.
EVERSOLO DMP-A8 GEN 2 : Préamplification analogique symétrique R2R
EVERSOLO DMP-A8 GEN 2: New Octa-Core Platform and DDR5 Memory
The DMP-A8 Gen 2 adopts an upgraded hardware platform built around a 64-bit octa-core processor, combined with 8 GB of DDR5 RAM and 64 GB of eMMC storage. This configuration enables smoother management of the interface, streaming applications, music libraries and audio processing. The device also retains an M.2 NVMe PCIe 3.0 slot in 2280 format, now compatible with SSDs with a capacity of up to 8 TB, allowing a large music library to be stored directly.
EVERSOLO DMP-A8 GEN 2 : Nouvelle plateforme octocœur et mémoire DDR5
EVERSOLO DMP-A8 GEN 2: evotune™ Acoustic Correction and Advanced Bass Management
The DMP-A8 Gen 2 integrates advanced processing functions that allow playback to be adapted to the installation and room acoustics. It notably offers a parametric equalizer (PEQ), a room correction function, FIR filter support and advanced low-frequency management. A high-pass filter can be applied to the main speakers, while the subwoofer output crossover frequency can be adjusted between 40 and 500 Hz, in order to optimize the integration of the subwoofer with the main speakers.
EVERSOLO DMP-A8 GEN 2 : Correction acoustique evotune™ et gestion avancée du grave
EVERSOLO DMP-A8 GEN 2: 8.6-inch Touchscreen and Control
The DMP-A8 Gen 2 features a new 8.6-inch color touchscreen combined with a completely redesigned graphical interface. It can display album artwork, playback information, file resolution as well as different displays with animated VU meters. The device can also be controlled from the EverSolo Control application for iOS and Android or with the supplied remote control.
EVERSOLO DMP-A8 GEN 2 : Écran tactile 8.6 pouces et contrôle
EVERSOLO DMP-A8 GEN 2: Hi-Res Streaming, AirPlay and Bluetooth 5.4
Thanks to its EOS system, the DMP-A8 Gen 2 provides access to numerous streaming services directly from its interface, including Qobuz, Tidal, Amazon Music, Spotify, Deezer, Apple Music, HighResAudio, Napster, IDAGIO, TuneIn, Radio Paradise, SoundCloud and Presto Music. It also supports Spotify Connect Lossless, TIDAL Connect and Qobuz Connect, as well as DLNA and AirPlay. Wireless connectivity benefits from Bluetooth 5.4 reception and dual-band 2.4/5GHz Wi-Fi 6.
EVERSOLO DMP-A8 GEN 2 : Streaming Hi-Res, AirPlay et Bluetooth 5.4
EVERSOLO DMP-A8 GEN 2: Gigabit Network, Wi-Fi 6 and SFP
The DMP-A8 Gen 2 features a Gigabit 10/100/1000 Mbit/s RJ45 Ethernet interface, complemented by dual-band Wi-Fi 6. An SFP interface also allows the use of an optical network connection, thereby electrically isolating the network from the player. The port accepts single-mode optical modules with single or dual fiber as well as copper Ethernet SFP modules, the latter sold separately. The player is also Roon Ready and can access music stored on a NAS or computer via compatible network protocols.
EVERSOLO DMP-A8 GEN 2 : Réseau Gigabit, Wi-Fi 6 et SFP
EVERSOLO DMP-A8 GEN 2: Dual Power Supply and Enhanced Isolation
The EVERSOLO DMP-A8 Gen 2 benefits from a dual low-noise power supply, separating the analog and digital sections in order to limit electrical interactions between the different circuits. This architecture is complemented by enhanced electrical isolation, helping to reduce noise and interference that could affect audio signals. The analog section therefore has a dedicated power supply, while the digital circuits benefit from their own power supply, for an optimized signal quality design.
EVERSOLO DMP-A8 GEN 2 : Double alimentation et isolation renforcée
EVERSOLO DMP-A8 GEN 2: Comprehensive Connectivity and Subwoofer Output
The DMP-A8 Gen 2 offers particularly comprehensive connectivity for centralizing the digital and analog sources of a HiFi system. It features 2 optical inputs, 1 coaxial input, 1 USB-B Audio, 1 HDMI ARC/eARC, 1 RCA input and 1 XLR input. The outputs include 1 optical, 1 coaxial, 1 HDMI I²S, 1 AES/EBU, 2 USB-A Audio, 1 RCA, 1 XLR and 1 dedicated subwoofer output, in addition to the RJ45 and SFP network interfaces. The optical and coaxial inputs and outputs support up to 24-bit / 192 kHz PCM and DSD64 via DoP, while the USB Audio and HDMI I²S outputs support up to 32-bit / 768 kHz PCM and native DSD512. The HDMI ARC/eARC input supports stereo PCM up to 24-bit / 192 kHz.
EVERSOLO DMP-A8 GEN 2 Network Player Overview
Aperçu du lecteur réseau EVERSOLO DMP-A8 GEN 2
1WiFi / BT antennas
2Mains power supply
3Digital outputs: AES/EBU, Toslink Optical, Coaxial SPDIF
4USB-A 3.0 OTG Input / USB-A Output
5SFP fiber port
6RJ45 ethernet port
7Digital inputs: HDMI ARC, Toslink optical, Coaxial SPDIF
8I2S output via HDMI
9USB-B input
10Subwoofer Output
11Trigger IN/ OUT
12Analog inputs: RCA / Balanced XLR
13Analog outputs: RCA / Balanced XLR
Sortie I2S
Technical Specifications
Product TypeNetwork Player
DAC
R2R Preamplifier
Touchscreen8.6" LCD Full HD
RAM8GB DDR5
ROM64GB eMMC
ProcessorEversolo Aural Engine
DACAK4499EXEQ + AK4191EQ
USB InterfaceXMOS XU316
Bluetooth ChipQCC3095
AOPOPA1612
Power SupplyLow-noise dual linear + digital power supply
Audio ClockTwo ultra-low phase-noise clocks
SSD SupportM.0 NVME 3.0 protocol 2280 up to 8TO (SSD sold separately)
Inputs1x USB-B
1x USB-A 3.0 (OTG)
1x HDMI ARC
1x Toslink Optical
1x Coaxial SPDIF
1x RCA
1x Balanced XLR
WiFi 6
Bluetooth 5.4
SFP Port
RJ45 Port
Outputs1x USB-A
1x I2S Via HDMI
1x Optical SPDIF
1x Coaxial SPDIF
1x RCA
1x Balanced XLR
1x Subwoofer
WiFi 6
TriggerIN 3.5mm jack
OUT 3.5mm jack
Wireless ConnectivityWiFi 6 2.4G+5G dual-band
Bluetooth 5.4
Supported Sampling RatesUSB-B Input: PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial: PCM up to 24bit 192kHz, DSD DoP64
HDMI ARC/eARC: PCM up to 24bit 192kHz
USB-A Output: PCM up to 32bit 768kHz, DSD up to DSD512 (Compatible only with USB DACs compliant with the UAC standard.)
I2S via HDMI: PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial / AES/EBU: PCM up to 24bit 192kHz, DSD DoP64
Supported Streaming ServicesTIDAL, Qobuz, HIGHRESAUDIO, Amazon Music, IDAGIO, Calm Radio, Internet Radio, TuneIn, Radio, Paradise, Deezer, SoundCloud, Presto Music, Apple Music...
Supported Transmission ProtocolsSpotify Connect Lossless, TIDAL Connect, Qobuz Connect, DLNA, Network Audio Adapter...
Supported Bluetooth CodecsSBC
AAC
aptX
aptX HD
aptX LL
LDAC
Compatible OS (USB)Windows 10 / 11
Android
iOS
RCA Output
Output Level2.1Vrms
Frequency Response20Hz - 20kHz (±0.25dB)
THD+N0.000086% (-121 dB)
Crosstalk> 131 dB
Dynamic Range> 127dB
SNR> 127dB
XLR Output
Output Level4.2Vrms
THD+N0.000075% (-122 dB)
Crosstalk> 129dB
Dynamic Range> 129dB
SNR> 133dB
Power Supply Voltage110-240VAC 50/60Hz
Rated Power30W
Dimensions388*265*88mm
Weight5.25kg
Package1x EverSolo DMP-A8 GEN 2
1x Remote Control
1x Trigger Cable
1x Power Cable
InputHDMI eARC
InputXLR
InputWiFi
OutputSubwoofer
OutputAES/EBU
OutputOptical Toslink
OutputI2S LVDS via HDMI
OutputCoaxial SPDIF
OutputWiFi
OutputUSB
DAC / ADC ChipAK4499EX
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
Streaming services & Network protocolsQobuz Connect
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsApple Music
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
EVERSOLO DMP-A8 GEN 2 Network Player AK4499EX AK4191EQ XMOS XU316 WiFi DLNA AirPlay Bluetooth aptX HD LDAC 32bit 768kHz DSD512
Second generation of the DMP-A8, the network player EVERSOLO DMP-A8 GEN 2 retains the same technical foundation with its AK4191EQ + AK4499EX...
