FERRUM BROEN Streamer Digital Transport
The Ferrum BROEN is a network transport designed to play digital audio content and transmit it to an external DAC. It is based on the Volumio platform and supports the main streaming services, UPnP/DLNA network playback, AirPlay, Internet radio as well as CD playback, while allowing multiroom management depending on the equipment used. Its role is to centralize playback and provide the DAC with a digital output suited to the installation.
By buying this product you get 198 loyalty points
Reference : 22347
1 989,00 €tax incl.
1 657,50 € tax excl.
FERRUM BROEN Streamer Digital Transport WiFi 6 Bluetooth
FERRUM BROEN: Front view
Ferrum BROEN: Volumio platform
The integration of Volumio gives access to Spotify and Spotify Connect, Tidal and Tidal Connect, Qobuz, AirPlay, UPnP/DLNA servers and Internet radio. Control is carried out from a smartphone, tablet or computer, via the Volumio interface and its functions for searching, sorting and displaying information about albums and artists. Firmware updates can be performed remotely, while the platform supports the addition of compatible plugins.
Ferrum BROEN: SERCE module and digital processing
The BROEN incorporates the SERCE module, dedicated to internal digital conversions and processing. Its architecture separates the input and output domains, while the digital audio outputs benefit from galvanic isolation designed to limit the propagation of interference between the different circuits. Low-jitter internal clocks ensure the synchronization of digital streams before their transmission to the DAC.
Ferrum BROEN: Network connectivity
Connection to the network can be made over Wi-Fi or by wired link, via the RJ45 Ethernet port or the SFP slot. The latter accepts a standard Ethernet module or an optical module, allowing the link to be adapted to the network infrastructure used and to physically separate data transport when the installation requires it. An internal SSD slot (SSD not included) is also provided to expand local storage possibilities.
Ferrum BROEN: Digital outputs
The BROEN offers several output formats to adapt to different DACs: AES/EBU on XLR, S/PDIF coaxial on RCA, S/PDIF optical TOSLINK, I2S and USB on type A and type C connectors. This connectivity allows the appropriate link to be selected according to the DAC used, while also enabling the connection of an external screen via HDMI to display the Volumio interface.
Ferrum BROEN: Ferrum FSCT integration
Thanks to Ferrum Streaming Control Technology, the BROEN can be paired with the Ferrum WANDLA and ERCO Gen 2 DACs (sold separately). Control from the WANDLA's touchscreen or remote allows playback to be managed and track information to be displayed without directly using the network transport's interface. This integration facilitates the use of the BROEN in a system entirely made up of Ferrum components.
Technical specifications
Product typeDigital Transport
Inputs1x USB-A
1x USB-C
1x HDMI video
1x SFP RJ45 / Optical port
WiFi
Bluetooth
Outputs1x USB-A
1x USB-C
1x HDMI I2S
1x Coaxial
1x AES
ConnectivityAirPlay
UPnP
DLNA
Supported audio formatsMP3, WMA, AAC, ALAC, FLAC,APE, WAV, DSD
Supported streaming servicesSpotify & Spotify Connect
TIDAL & TIDAL Connect
Qobuz
Supply voltage22-30V DC / 2.5A
Dimensions217 x 206 x 50mm
Weight1.90kg
Package1x Ferrum BROEN
1x Power adapter
1x Remote control
1x SFP RJ45 module
1x WiFi antenna
InputSFP
InputWiFi
InputHDMI
OutputI2S LVDS via HDMI
OutputAES/EBU
OutputUSB
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rateNC
Remote ControlYes
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsUpnP
Streaming services & Network protocolsTidal
Streaming services & Network protocolsTidal Connect
The Ferrum BROEN is a network transport designed to play digital audio content and transmit it to an external DAC. It is based on the Volumio...
