KECES EUPHONY Discrete Balanced DAC Streamer
The KECES EUPHONY is a discrete balanced DAC with an integrated network streamer function, designed to provide high-quality digital-to-analog conversion while allowing playback of files and streaming services without requiring an external network transport.
By buying this product you get 119 loyalty points
Reference : 22484
1 199,00 €tax incl.
999,17 € tax excl.
KECES EUPHONY Discrete Balanced DAC Streamer WiFi DLNA Bluetooth 5.1 32bit 384kHz DSD256
KECES EUPHONY
The KECES EUPHONY is a discrete balanced DAC with an integrated network streamer function, designed to provide high-quality digital-to-analog conversion while allowing playback of files and streaming services without requiring an external network transport. Its fully balanced architecture incorporates a discrete-component I/V conversion stage to promote low distortion, good dynamics, and precise reproduction. Digital processing supports PCM up to 32bit/384kHz via USB and up to 24bit/192kHz via optical and coaxial inputs, as well as DSD up to DSD256 via USB and DSD64 via optical/coaxial. Compatible with MP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG, and AIFF formats, it is a versatile solution for playing high-resolution digital sources.
The streamer function relies on dual-band 2.4/5GHz Wi-Fi 802.11 b/g/n/ac connectivity and 10/100M Ethernet, with support for DLNA, Spotify Connect, and TIDAL Connect protocols, as well as Spotify, Deezer, TuneIn, Tidal, Qobuz, and other services. Bluetooth 5.1 further expands the wireless connectivity options. The Euphony also benefits from a particularly carefully designed power supply featuring a proprietary KECES H-Sonic™ toroidal transformer, developed, designed, and manufactured in-house, as well as independent power supply blocks dedicated to the digital, analog, and MCU sections to limit interference and preserve signal purity.
In terms of connectivity, the KECES EUPHONY features USB, optical, and coaxial digital inputs, optical and coaxial digital outputs, as well as balanced XLR analog outputs on lockable Neutrik connectors and 24K gold-plated RCA outputs. The analog outputs offer an SNR greater than 110dB and THD+N lower than 0.01%, with an output level of 4.5Vrms via XLR and 3Vrms via RCA. The device accepts switchable 115/230V AC power, 50/60Hz, and measures 220 × 220 × 66mm for a weight of 3kg, allowing digital conversion, network streaming, and high-fidelity analog output to be integrated into a compact chassis.
Overview of the KECES EUPHONY
1Stereo RCA output
2Balanced XLR output
3Coaxial SPDIF output
4Toslink optical output
5Antenna
6Coaxial SPDIF input
7Toslink optical input
8USB-A Host input
9RJ45 ethernet port
10USB-B input
11115-230V AC 50/60Hz mains power supply
12Power switch
Technical specifications
Product typeDAC Streamer
Inputs1x USB-B
1x USB-A Host
1x Coaxial SPDIF
1x Toslink Optical
WiFi
Bluetooth 5.1
Outputs1x RCA
1x XLR
1x Coaxial SPDIF
1x Toslink Optical
Supported sampling rateUSB : PCM 32bit 384kHz, DSD256
Toslink Optical, Coaxial SPDIF : 24bit 192kHz, DSD64
NetworkDual-band Wi-Fi 802.11 b/g/n/ac at 2.4GHz and 5GHz
10/100M Ethernet
Supported audio formatsMP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG, AIFF
Streaming protocolsDLNA, SpotifyConnect, TIDAL Connect
Streaming servicesSpotify, Deezer, TuneIn, Tidal, Qobuz, etc.
SNRRCA : > 110dB
XLR : > 110dB
THD+NRCA : < 0.01%
XLR : < 0.01%
Output levelRCA : 3Vrms< 0.01%
XLR : 4.5Vrms
Power supply115-230V AC 50/60Hz (Switchable)
Weight3kg
Dimensions220x220x66mm
Packaging1x KECES EUPHONY
InputWiFi
OutputCoaxial SPDIF
OutputSPDIF
DAC / ADC ChipNC
Max sampling rateDSD256
Max sampling rate384kHz
NetworkingYes
Remote ControlControl app
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
The KECES EUPHONY is a discrete balanced DAC with an integrated network streamer function, designed to provide high-quality digital-to-analog...
