Shanling PCD300B Hifi CD Player Headphone Amplifier DAC PCM1796
4.0 / 5
By buying this product you get 216 loyalty points
Reference : 9349
549,00 €tax incl.
457,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This CD player has been designed around a Philips 7824 servo and a SANYO HD870 laser scanner.
In addition, it is equipped with a Burr-Brown PCM1796 converter, a Burr-Brown OPA2134 AOP amplifier and a TPA6120 headphone amplifier capable of driving headphones up to 600 ohms.
The components have been chosen with the aim of offering you the best for a result of a high precision and a musicality that will make your listening more pleasant.
Characteristics :
  • SANYO HD870 laser read head
  • Servo Philips 7824
  • DAC Burr-Brown PCM1796
  • AOP Burr-Brown OPA2134
  • Integrated Headphone Amplifier TPA6120
  • R-Core Transformer
  • Output Level: 2V
  • Headphone output level max. : 100mW / 600 Ohm
  • Frequency response: 20Hz - 20kHz
  • Signal Noise Ratio:> 105dB
  • THD + N: <0.2% (1kHz)
  • Headphone Jack Out 6.35mm
  • Analog output: RCA
  • Digital Output: Coaxial SPDIF
  • Dimensions: 322x210x70mm
  • Weight: 3.4kg
[Img-8811-left-thickbox_default]
[Img-8812-left-thickbox_default]
[Img-8837-left-thickbox_default]
[Img-10384-left-thickbox_default]
Shanling PCD300B
CD300B "src =" http://audiophonics.com/img/cms/products/9349/9349_5.jpg "alt =" Shanling PCD300B "width =" 700 "height =" 638 "/>
Shanling PCD300B
Shanling PCD300B
Shanling PCD300B
Très bonne première impression !!
Installation : Shanling PCD300B + OYAIDE PA-02TR OCC + TP60 + (provisoirement) câbles HP bon marché + Technics 50W 6ohms pour rodage 100h.
Après 30h, l'ensemble retranscrit fidèlement la source lue, bonne comme mauvaise... Exactement ce que je cherchais !
Verdict sans appel aux 1ere lectures CD : Ça va du fabuleux ("All is time" Sting, "The girl in the other room" Diana Krall (Ouaouh!!), "Image" JMJarre, "Absolution" Muse, Peter Cincotti...), en passant par du moyen ("Ain'T Misbehavin" Dave Brubeck) jusqu'à du franchement médiocre ("Dangerous" M.Jackson, "The 2nd Law" Muse...). Preuve qu'en qualité CD on trouve de tout !!
A la fin du rodage, je teste plusieurs HP avec cet ensemble et mes superbes câbles HP 1877Phono NOVA OCC en vue d'un achat et je vous tiens au courant de mon choix final.
Bravo à Audiophonics pour les conseils, la rapidité de livraison et la qualité du matériel.
Pour info, le PCD300B a bel et bien une commande de volume avec la télécommande (à priori via un potentiomètre interne motorisé ALPS27)
A suivre...
This review has been posted for Shanling PCD300B Hifi CD Player Headphone Amplifier DAC PCM1796
