KECES EWAVE Network Switch 8x RJ45
The Keces Ewave is a network switch designed for the most demanding systems. It features eight 10/100/1000 Mbps-compatible ports and is based on an in-house circuit design, with routing and layout optimised to minimise electromagnetic interference (EMI/RFI) and ensure consistent data transmission.
By buying this product you get 149 loyalty points
Reference : 21693
1 499,00 €tax incl.
1 249,17 € tax excl.
Keces Ewave Network Switch 8x RJ45
Keces Ewave : Front view
This architecture is based on an independent power supply for each critical section – the network chip, OCXO clock, inputs, outputs and microcontroller – thereby minimising electrical interactions between stages whilst ensuring overall operational stability. In line with this, the 25 MHz OCXO provides a low-phase-noise timing reference, stabilising the timing of network packets to limit synchronisation variations.
Individual control of each port allows for the selective activation of connections, reducing interference between active lines whilst facilitating integration into scalable configurations. In addition to this granular management, audio-oriented QoS prioritisation organises traffic to give priority to sensitive streams, ensuring uninterrupted delivery without congestion.
Designed to provide the backbone for a dedicated network, it combines granular port management with compartmentalised power supply, enabling connections to be centralised whilst maintaining stable and predictable operation.
Technical Specifications
Product TypeNetwork switch
Interface8x RJ45 Ethernet ports 10/100/1000Mbps
Power supply12V DC / 1A
Dimensions220 x 220 x 66mm
Weight4kg
Package1x Keces Ewave
The Keces Ewave is a network switch designed for the most demanding systems. It features eight 10/100/1000 Mbps-compatible ports and is based on an...
