LHY AUDIO AS6 PRO Network Switch Black
The LHY AUDIO AS6 PRO is an audiophile network switch designed for demanding Hi-Fi systems requiring high bandwidth and advanced isolation between internal circuits.
By buying this product you get 99 loyalty points
Reference : 22486
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 01-12-2026.
LHY AUDIO AS6 PRO Network Switch 4x RJ45 2.5G 2x 10G Optical Fiber Black
LHY AUDIO AS6 PRO
The LHY AUDIO AS6 PRO is an audiophile network switch designed for demanding Hi-Fi systems requiring high bandwidth and advanced isolation between internal circuits. Building on the AS6's OCXO clock architecture while introducing significant improvements, it features four 2.5GbE RJ45 Ethernet ports and two 10GbE SFP+ optical ports, providing high-performance connectivity for music servers, streamers, and modern network infrastructures. Its four-zone internal architecture enhances isolation between the various circuit stages to minimize interference. It also includes a 10MHz external clock input on a 50Ω BNC connector, compatible with both sine wave and square wave signals (7-14dBm / 0.5-1Vrms), as well as a high-precision OCXO oscillator offering a typical phase noise of -100dBc at 1Hz offset, frequency stability of < ±5ppb, and frequency accuracy of < ±0.05ppm. The switch supports IEEE 802.3 / 802.3u / 802.3ab, IEEE 802.3bz / 802.3cb (2.5GbE), IEEE 802.3ae (10GbE), IEEE 802.3az (EEE), IEEE 802.1p (QoS/CoS), as well as IEEE 802.1BA / 802.1AS AVB protocols for synchronized audio/video streams. It supports Jumbo Frames up to 12,288 bytes (12KB) and features an independent grounding terminal with a Float / Grounded selector, allowing the chassis grounding behavior to be adapted to the installation. Its 256 × 175 × 50mm, 3.3kg chassis benefits from an optimized thermal dissipation system. The power supply is available in either 220-240VAC or 110-120VAC versions depending on the factory configuration, with a power consumption of 5W in standby and 16W under full load. Included accessories comprise an SFP module, an RJ45 Ethernet cable, and a power cord.
LHY AUDIO AS6 PRO
LHY AUDIO AS6 PRO: High-Speed 2.5GbE and 10GbE Connectivity
The LHY AUDIO AS6 PRO is equipped with 4x 2.5GbE RJ45 Ethernet ports and 2x 10GbE SFP+ optical ports, delivering connectivity tailored to modern high-speed audio networks. Compatible with major Ethernet standards up to 10 Gigabit, it also supports Jumbo Frames up to 12KB, IEEE 802.1p QoS/CoS priority management, and AVB protocols (IEEE 802.1BA / 802.1AS) for optimized transmission of synchronized audio and video streams.
LHY AUDIO AS6 PRO: High-Precision OCXO Clock and 10MHz External Synchronization
The switch incorporates an ultra-low phase noise OCXO oscillator (-100dBc @ 1Hz, typical), ensuring outstanding timing stability (< ±5ppb) and frequency accuracy (< ±0.05ppm). It also features a 10MHz BNC input compatible with external master clocks, accepting both sine wave and square wave signals for seamless integration of a shared clock reference into a high-end audiophile system.
LHY AUDIO AS6 PRO: Optimized Architecture and Grounding Control
The LHY AUDIO AS6 PRO adopts a four-zone internal architecture designed to enhance isolation between the different circuits and reduce unwanted interference. Its improved thermal dissipation system ensures stable operation over extended periods. Finally, its independent grounding terminal combined with a Float / Grounded selector allows the grounding strategy to be adapted to the installation, optimizing the switch's electrical integration within an audio system.
Technical Specifications
Product typeNetwork switch
Network standardsIEEE 802.3 / 802.3u / 802.3ab (10/100/1000Mbps), IEEE 802.3bz / 802.3cb (2.5Gbps / 2500BASE-X), IEEE 802.3ae (10Gbps 10GBASE-SR/LR), IEEE 802.3az (EEE), IEEE 802.1p (QoS / CoS), IEEE 802.1BA / 802.1AS (AVB)
RJ45 ports4× RJ45 2.5Gbps
SFP+ ports2× SFP/SFP+ 10Gbps
Jumbo FramesUp to 12,288 Bytes (12KB)
Clock input10MHz BNC (50Ω), sine wave or square wave signal, 7-14dBm / 0.5-1Vrms
Internal oscillatorOCXO
OCXO phase noise-100dBc @ 1Hz Offset (typical)
Frequency stability< ±5ppb
Frequency accuracy< ±0.05ppm
Grounding1× Independent ground terminal + Float / Grounded selector
Front panel indicators1× Power indicator
2× Clock mode indicators
RJ45 indicatorsGreen LED: 1000/100Mbps (LINK solid / ACT flashing), Orange LED: 2.5Gbps (LINK solid / ACT flashing)
SFP+ indicatorsOrange LED (LINK solid / ACT flashing)
Dimensions (W × D × H)256 × 175 × 50mm
Weight3.3kg
Power supply220~240VAC
Power consumption5W (standby) / 16W (full load)
Fuse5 × 20mm T1.0AL (220~240VAC)
Package contents1x LHY AUDIO AS6 PRO
1x Power cord
1x SFP module
1x RJ45 Ethernet cable
LHY AUDIO AS6 PRO Network Switch 4x RJ45 2.5G 2x Fiber Optic 10G Black
The LHY AUDIO AS6 PRO is an audiophile network switch designed for demanding Hi-Fi systems requiring high bandwidth and advanced isolation between...
