LHY AUDIO AS8 Pro+ Network Switch Silver
LHY Audio offers us their AS8 Pro+ network switch. It features 6 RJ45 Ethernet ports and 2 SFP fiber optic ports, as well as a dedicated input and output connected to its built-in 10MHz OCXO SC-CUT clock. Everything is housed in an elegant CNC-machined anodized aluminum chassis designed to minimize resonance and engineered to physically separate data processing, audio signal processing, internal clock circuitry, and the power supply stage.
By buying this product you get 229 loyalty points
Reference : 21525
2 299,00 €tax incl.
1 915,83 € tax excl.
Shipping date: 01-12-2026.
LHY AUDIO AS8 Pro+ Network Switch 6x RJ45 2x Fiber Optic Silver
LHY AUDIO AS8 Pro+ : Front view
Comparison — AS8 Pro vs AS8 Pro+
FeatureAS8 ProAS8 Pro+
Master ClockUltra-stable 10 MHz OCXOMilitary-grade SC-CUT OCXO with even lower phase noise
Clock PrecisionVery highEven higher (better coherence)
Network Path IsolationIsolated audio zone + main zoneIsolated audio zone + main zone, enhanced internal isolation
Network Ports1G, 2.5G, 10G + SFP/SFP+1G, 2.5G, 10G + SFP/SFP+
Clock DistributionStandardMore refined clock distribution
Internal Power SupplyClean linear power supplyUpgraded linear power supply
Power Capacitors6 high-quality capacitors12 very high-quality capacitors
Internal WiringHigh-end standard conductorsOyaide 102SSC high-conductivity conductors
EMI ProtectionStandard internal shieldingInternal shielding + advanced MagShield™
Internal DecouplingYesYes, optimized
Jitter ReductionOptimizedFurther reduced
Soundstage / Audio PrecisionHighDeeper and more precise
LHY Audio AS8 Pro+: Stable Power Supply with No Parasitic Noise
The AS8 Pro features two 50VA transformers delivering a regulated linear power supply coupled with an RFI suppression filter. Once converted, the current passes through a multi-stage low-drop voltage regulator and a voltage rectifier to ensure the cleanest possible power delivery.
LHY Audio AS8 Pro+: OCXO SC-CUT Clock
For signal processing, the LHY Audio AS8 Pro+ offers 6 RJ45 ports, including two with digital isolation, and two optical SFP ports, one of which also benefits from digital isolation. At its core lies a 10MHz OCXO SC-CUT clock, connected to both a BNC input and output. This allows the switch to function as a master clock to synchronize other external sources or simply to reclock the incoming signal. Finally, it is worth noting that the OCXO SC-CUT clock is paired with a PLL (Phase-Locked Loop) system.
AS8 Pro+ Overview
LHY AUDIO AS8 Pro+ : rear panel diagram
1Power switch
2Fuse
3AC power input
4Ground switch
5Ground terminal
650Ω BNC input and output
7SFP+ indicator LED
810Gb/s SFP+ port
92.5Gb/s RJ45 ports
10Isolated 1Gb/s RJ45 ports
11Isolated 1Gb/s SFP port
12SFP+ indicator LED
Technical Specifications
Product TypeFiber Optic Ethernet Network Switch
Interface4x RJ45 Ethernet ports
2x Isolated RJ45 Ethernet ports
1x SFP+ Fiber Optic connector
1x Isolated SFP Fiber Optic connector
1x 10MHz BNC clock input (50Ω input impedance)
1x 10MHz BNC clock output (50Ω output impedance)
Clock Phase Noise-110dBc @1Hz
Clock Frequency Stability< ±5ppb
Clock Frequency Accuracy< ±0.5ppm
Power Supply220V - 240V AC
Power ConsumptionStandby: 18W
Operating: 28W
Dimensions400 x 260 x 55mm
Weight5.5kg
ColorSilver
Package Contents1x LHY Audio AS8 Pro+
1x Power cable
LHY AUDIO AS8 PRO+ Network Switch 6x RJ45 2x Optical Fiber Silver
LHY Audio offers us their AS8 Pro+ network switch. It features 6 RJ45 Ethernet ports and 2 SFP fiber optic...
