AUDIOPHONICS RaspDAC LTE 502DAC - Analog / Digital Streamer PCM5122
By buying this product you get 26 loyalty points
Reference : 11992
269,00 €tax incl.
224,17 € tax excl.
Audiophonics Raspdac LTE V2
502DAC PCM5122 Raspberry Pi 3
The Raspdac LTE V2 + Raspberry Pi 3 returns in a brand new version equipped with a 502DAC converter.
The dematerialized within reach of hands
RaspDAC LTE V2 ST4000 ES9018K2M Raspberry Pi 3
Go to high definition dematerialized with RaspDAC LTE. Housing Aluminum and Plexiglas,502DAC 24bit / 196kHz,Raspberry Pi 3!
It is an affordable solution of dematerialized reading assembled and tested in our workshops, in France.
Network drive complete and ready to use electronically, you only have to opt for the software solution of your choice (piCorePlayer, Max2Play, Openelec ...).
Compatible Max2Play
Compatible piCorePlayer
An all-in-one solution
If this RaspDAC LTE 502DAC is so effective, it is also because it presents a great versatility. Thus, you canyou can enjoy both analogue and digital (all formats).
A high-end audio player with the 502DAC PCM5122
Thanks to the 502DAC converter PCM5122you get a high-end dematerialized audio player, accepting resolutions up to 24bit / 192kHz and allows the use of an AES / EBU output..
Optimized for dynamic and accurate sound reproduction, this 502DAC is equipped with two clocks NDK NZ2520SDto ensure the lowest possible jitter and reduce phase noise.
In addition, a WM8804 chip converts the I2S stream into Pro-Audio AES / SPDIF at 24bit / 192kHz. The DAC also features an LDO LT3042 and two Puls PE-65612 audio isolation transformers.
Finally, the system offers a complete connection : 4 USB 2.0 portsto connect the devices of your choice (USB stick, hard disk ...), 1 Ethernet port to enjoy the files stored on your network, a micro SD port for the OS, HDMI output, gold-plated RCA output, Toslink output, 6.35 AES / EBU jack output with XLR adapter and BNC output with RCA adapter to connect your favorite audio devices. So you have a complete range of connectors to meet all your needs and can take advantage of new integration possibilities in your audio systems.
Raspberry
Pi 3 Model B
502 DAC
PCM5122
Design
Exclusive
Design and reliable
Specially designed to allow you to have the effectiveness of your Raspberry Pi ina high quality audio environment, it turns out to be as elegant and discreet so you can easily integrate it into your system.
The couple Raspberry Pi 3 and 502DAC, integrated in an Aluminum and Plexiglas box designed in our workshops will prove to be especially strong and durable.
RaspDAC LTE V2 502DAC
TECHNICAL CHARACTERISTICS
CONNECTORS
Inputs Raspberry Pi 3:
  • 4x USB-A
  • 1x Ethernet RJ45
  • 1x Micro SD
Outputs 502DAC:
  • 1x RCA stereo
  • 1x HDMI
  • 1x AES / EBU via 6.35mm jack with XLR adapter
  • 1x BNC with RCA Adapter
  • 1x Toslink
SPEC 502DAC
  • Clocks: 2x NDK NZ2520SD
  • Wolfson WM8804
  • LDO: LT3042
  • Sample Rate: 24bit / 192kHz
  • THD: -112dB
VARIOUS
  • Dimensions: 102 x 169 x 58mm
  • Color: Black / Silver
  • Chassis: Aluminum & Plexiglas
  • Weight: 676g
  • Power Supply: Jack DC 5.5 / 2.1mm
  • Accessories: 5V 2A power cord / 6.35 to XLR Jack adapter / BNC to RCA adapter
