RaspTouch 502DAC - Streamer Digital / Analog PCM5122
By buying this product you get 40 loyalty points
Reference : 12049
409,00 €tax incl.
340,83 € tax excl.
RASPTOUCH 502DAC
Open Source Streamer Raspberry 3 - Pi2Design 502DAC
rasptouch 502DAC
Audiophonics is back with a new version of the RaspTouch, for experienced audiophiles. It includes a Raspberry Pi 3 and a 502DAC converter from Pi2Design. Supporting resolutions up to 24bit / 192kHz and offering an AES/EBU output, this RaspTouch offers optimal sound quality.
rasptouch 502dac
Complete compatibility
Supplied with a Micro SD card for the OS installation, there are many operating system options to choose from, depending on your preferences and needs.
Ready to use electronically, many software solutions exist to meet all your expectations: piCorePlayer, Max2Play, OpenElec...
Multiroom without limits
Do you want to enjoy your music throughout your home? The Rasptouch offers you an efficient multiroom system, allowing you to stream your files on any turntable connected to your network and control them.
High-end audio player thanks to the 502DAC PCM5122
Thanks to the 502DAC PCM5122 converter you get a top-of-the-range dematerialized audio player, accepting resolutions up to 24bit / 192kHz and allowing the use of an AES/EBU output.
Optimised to give you a dynamic and accurate sound reproduction, this 502DAC is equipped with two NDK NZ2520SD clocks to ensure the lowest possible jitter and reduce phase noise.
In addition, a WM8804 chip converts the I2S stream to Pro-Audio AES/SPDIF at 24bit / 192kHz. The DAC also includes an LDO LT3042 and two Puls PE-65612 audio isolation transformers.
In the end, the system offers a complete connection: 4 USB 2.0 ports to connect the peripherals of your choice (USB key, hard disk...), 1 Ethernet port to enjoy the files stored on your network, a micro SD port for the OS, an HDMI output, a gold-plated RCA output, a Toslink output, an AES/EBU XLR format output and a BNC output with RCA adapter. This means you have a full range of connectors to meet all your needs and can take advantage of new integration possibilities in your audio systems.
Raspberry Pi
Version 3 Model B
502DAC
PCM5122
Design
Exclusive
Ergonomic and design
Featuring a 7"touch screen, it allows you to easily and intuitively control your audio library via a graphical interface.
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and matt appearance give it a modern and contemporary design. A device that will fit perfectly into your high-end audio system.
rasptouch 502dac
Connectors : Inputs (RPI 3)
USB-A4x
Ethernet RJ-451x
Slot Micro SD1x
Connectors : Outputs (502DAC)
Stereo RCA1x
HDMI1x
AES/EBU XLR1x
BNC with RCA adapter1x
Toslink1x
Raspberry Pi 3
SoCBroadcom BCM2837 1.2GHz
CPUARM Cortex A53 64bit 4 coeurs
Wifi802.11 b/g/n
Bluetooth4.1
LPDDR2 Memory1Go
502DAC
Clocks2x NDK NZ2520SD
Digital interfaceWolfson WM8804
LDOLT3042
Sampling rate24bit 192kHz
THD-112dB
Screen7" capacitive touch screen
Screen resolution800 x 400px
ColorNoir
Case materialAluminium and Plexiglass
Dimensions200 x 95 x 230mm
Power supplyJack DC 5.5/2.1mm - 7.5V 2.9A (Included)
AccessoriesJack 6.35mm to XLR Adapter
BNC to RCA Adapter
