Dayton Audio ND65-PR Passive Radiator Aluminum 6.5cm
The Dayton Audio ND65-PR is a 6.5cm passive radiator designed to tune small speakers to a lower frequency without increasing their volume. It uses a rigid black anodized aluminum cone, a rubber surround and an adjustable mass thanks to the included threaded rod, wing nut and 4.3g disc. Its resonant frequency is 73Hz and its adjustable mass allows a wide range of tuning frequencies. Its appearance matches that of the ND series speakers, for use in compact systems, sound bars or portable Bluetooth speakers.
Reference : 22307
12,00 €tax incl.
10,00 € tax excl.
Shipping date: 12-11-2026.
Dayton Audio ND65-PR Passive Radiator Speaker Aluminum 6.5cm
Photo du DAYTON AUDIO ND65-PR Passive Radiator Speaker Aluminum 6.5cm
Dimensional drawing of the Dayton Audio ND65-PR
Technical specifications
Product typePassive radiator
Nominal diameter6.5cm
Thiele-Small parameters
Resonant frequency (Fs)73Hz
Cone surface area (Sd)15.6cm²
Mechanical quality factor (Qms)2.69
Total moving mass + air load on cone (Mms)3.2g
Mechanical compliance of suspension (Cms)1.45mm/N
Compliance equivalent volume (Vas)0.02ft³
Max linear excursion (Xmax)5mm
Mounting informations
Cutout diameter5.2cm (2.05")
Depth4.8cm (1.89")
Total external diameter6.5cm (2.52")
Number of mounting holes4
Materials
ConeAluminum
FrameSteel
SurroundRubber
Weight0.045kg
Package1x Dayton Audio ND65-PR
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)65
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
The Dayton Audio ND65-PR is a 6.5cm passive radiator designed to tune small speakers to a lower frequency without increasing their volume. It uses...
