DAYTON AUDIO RSS210-PR Passive Radiator Aluminum
This RSS210-PR passive radiator from Dayton Audio is ideal for a DIY subwoofer project in combination with an active speaker. It features a thick black anodised aluminium cone and a rigid cast aluminium frame. This speaker is therefore aesthetically similar to the brand's reference series of subwoofers. Its design incorporates an SMS (Sandwich Mass System) for greater linearity by minimising angular torque. Weighted discs are included for simple and effective adjustment of this passive radiator.
Reference : 21303
99,90 €tax incl.
83,25 € tax excl.
Shipping date: 17-11-2026.
Grantie 5 ans
Dayton Audio RSS210-PR Passive Radiator Aluminum Ø20.32cm
DAYTON AUDIO RSS210-PR : Front view
DAYTON AUDIO RSS210-PR : Dimensions
The RSS210-PR passive radiator is useful for enjoying deeper, richer sound in the low frequencies. It extends the bandwidth of a speaker and gives your active speakers a boost, allowing them to venture more easily into the bass range.
Product typePassive radiator
Nominal diameterØ20.32cm (8")
Thiele-Small parameters
Resonance frequency (fS)19.5 Hz
Mechanical quality factor (QMS)10.70
Air volume equivalent to suspension (VAS)39.2 L
Suspension flexibility (CMS)0.61 mm/N
Air volume displaced at Xmax (VD)426.0 cm³
Moving mass + air load (MMS)110.0g
Maximum linear excursion (XMAX)20 mm
Membrane surface area (SD)213.0 cm²
Weight176g
Package1x Dayton Audio RSS210-PR
4x 75g weight discs
1x Locking nut
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)20.3
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)20.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
DAYTON AUDIO RSS210-PR Passive Radiator Aluminum Ø20.32cm
This RSS210-PR passive radiator from Dayton Audio is ideal for a DIY subwoofer project in combination with an active speaker. It features a thick...
