DAYTON AUDIO SS15-PR Passive Radiator
New
The Dayton Audio SS15-PR is a 38.1cm (15") passive radiator designed to extend the low-frequency response of high-output subwoofer enclosures, notably as a complement to the SS15-22 subwoofer. By replacing the traditional port, it allows tuning the enclosure without airflow noise, while avoiding the size constraints associated with a long port.
Reference : 22533
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 11-11-2026.
Grantie 5 ans
Dayton Audio SS15-PR Passive Radiator Passive Radiator 22.4Hz Ø38.1cm
DAYTON AUDIO SS15-PR: Front view
Its construction is based on that of the Signature Series range, with a cast aluminum frame, an anodized aluminum cone and a rubber surround. These elements are designed to accommodate the large excursions of a high-power system, while the Sandwich Mass Structure (SMS) system places the tuning mass between the spider and the surround to promote symmetrical movement.
Tuning is done using a threaded rod, a wing nut and a Nylock lock nut, which allow the added mass to be adjusted and secured. The five 116 g masses provided offer a margin for adapting the enclosure tuning. Paired with the SS15-22, the SS15-PR thus integrates into home theater and music systems requiring high-level low-frequency extension.
DAYTON AUDIO SS15-PR: Dimensions
Technical specifications
Product typePassive radiator
Nominal diameter38.1cm (15")
Thiele-Small parameters
Resonance frequency (Fs)22.4Hz
Cone surface area (Sd)804.3cm²
Mechanical quality factor (Qms)6.74
Force factor (BL)8T·m
Total moving mass + air load on the diaphragm (Mms)300g
Mechanical compliance of suspension (Cms)0.169mm/N
Compliance equivalent volume (Vas)5.48ft³
Max linear excursion (Xmax)35mm
Mounting informations
Cutout diameter35.30cm (13.9")
Depth13,97cm (5.5")
Total outer diameter38.86cm (15.3")
Materials
DiaphragmAluminum
FrameCast aluminum
SurroundRubber
Weight4.6kg
PackageSold individually
Speaker Power (W RMS)NC
Speaker TypePassive Radiator
Impedance (Ω)NC
Loudspeaker diameter (mm)381.0
Diaphragm typeAluminium
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
DAYTON AUDIO SS15-PR Passive Radiator 22.4Hz Ø38.1cm
The Dayton Audio SS15-PR is a 38.1cm (15") passive radiator designed to extend the low-frequency response of high-output subwoofer enclosures,...
