ASCILAB A6B Bookshelf Speakers Metallic Gray (Pair)
The AsciLab A6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6.5” PURIFI aluminum woofer, all housed in an enclosure with two Purifi passive radiators.
By buying this product you get 409 loyalty points
Reference : 20948
4 090,00 €tax incl.
3 408,33 € tax excl.
AsciLab A6BBookshelf Speakers 500W 4 Ohm 82dB Metallic Gray (Pair)
Ascilab A6B photo
The AsciLab A6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a 1“ alumina ceramic dome tweeter with custom waveguide and phase tapping, combined with a 6.5” Purifi aluminum woofer, all housed in an enclosure with two Purifi passive radiators. The Purifi 6.5" passive radiators provide a considerable boost at low frequencies. The frequency response of the A6B goes down to 32Hz (-6dB). Their design allows for lower crossover points and reduced distortion, for an extremely clear sound reproduction. The A6B feature a fourth-order crossover at 1kHz, optimized via Klippel NFS, and support up to 500W of amplification. These premium loudspeakers are ideal for demanding audiophile or professional studio use.
C6B designs
AsciLab A6B: Tweeters optimized for controlled sound dispersion
AsciLab A6B tweeters feature a waveguide and internal phase plug designed to precisely manage sound dispersion. These elements avoid phase interference, reduce internal resonance and improve off-axis dispersion. The advantages of this type of configuration translate into a more linear frequency response, reduced distortion and better spatialization of sound, offering a more coherent soundstage.
Zoom in on the A6B tweeter
Zoom in on the A6B woofer
AsciLab A6B: 6.5" Purifi woofer with aluminum cone
Despite their relatively compact size, the 6.5" Purifi woofers of the AsciLab A6B speakers are capable of sounding spaces of up to 25m², thanks to their powerful, well-defined bass. The aluminum cone ensures perfect low-frequency reproduction. It provides exceptional rigidity for faithful, distortion-free reproduction, even at high volume, thanks to a strong limitation of cone deformation at high sound pressure. Powerful and dynamic, these Purifi woofers deliver near-perfect performance.
AsciLab A6B: two 6.5" Purifi passive radiators for deep bass
AsciLab A6B speakers feature a passive radiator at the rear. These limit unwanted resonance while optimizing low-frequency reproduction. This solution also helps reduce distortion at high volumes, unlike a bass-reflex port, which can generate turbulence. AsciLab has also chosen to integrate two passive radiators to maintain a relatively compact speaker design.
A6B passive radiator
AsciLab A6B: non-magnetic crossover system and precise adjustment
The materials used in the A6B crossover system are non-magnetic, to avoid any hysteresis effects that could cause energy dissipation and distortion. Furthermore, each loudspeaker is tuned using a Klippel NFS system, for precise rendering.
The AsciLab A6B crossover system and tuning
AsciLab A6B test by Audio Science Review (Amir)
"This is a speaker you have to experience. It will easily blow away any expectations you have. I would give the A6B a serious consideration for mixing and mastering in smaller rooms. Needless to say, I am going to recommend the Ascilab A6B speakers."
Logo ASR
Product typePassive speakers
Channel number2-way
Tweeter1" alumina ceramic dome tweeter
Woofer6.5" aluminum cone woofer
DesignWith two passive radiators
Enclosure materialMDF
FinishMate
Crossover frequency1kHz
Sensitivity82dB @ 2.83V / 1M
SPL Max. (Full-bandwidth)102dB SPL
SPL Max. (>100Hz)106dB SPL
Frequency response-3dB @ 37Hz / -6dB @ 32Hz
ImpedanceNominal 4 ohm
Recommended amplification50W - 500W
Connection to speaker terminals4mm Banana
Bare wires
Spades
Dimensions40.5 x 22 x 30cm
Weight12.3kg/speakers
ColorMetallic Gray
Package1x Pair of AsciLab A6B speakers
ColorGray
Impedance (Ω)4
Efficiency / Sensitivity (dB)82.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
Power (W)500.0
Number of ways2
Number of loudspeakers4
Speaker typePassive
Speaker form factorBookshelf speaker
ASCILAB A6B Bookshelf Speakers 500W 4 Ohm 82dB Metallic Gray (Pair)
The AsciLab A6B are passive bookshelf speakers offering precise, powerful sound reproduction in a compact format. These 2-way speakers feature a...
