Enceintes Bibliothèques 2 Voies 80W 88dB 55Hz-20kHz (La paire)
The smaller Davis Acoustics model, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass boomer/midrange offering a good transient regime while ensuring low mechanical deformation, as well as a soft dome tweeter made of 25mm coated fabric. In addition, the speaker body contains a high quality crossover filter, providing linear listening for long hours of listening without listening fatigue while providing accurate playback. A Bass Reflex system with a large front vent allows you to deliver deep bass. The frontal positioning of these vents allows the MIA 20 to be placed directly against a wall. The 88dB efficiency of these speakers allows them to be associated with all amplifiers on the market.
At the rear, the speaker offers screw terminals that accept banana plugs, but also a system that allows the speakers to be simply positioned against a wall.
" Listening, the Davis Mia 20 are real HiFi speakers that have a lot of charm. For the price at which they are offered, there is not much to complain about. We know of many more expensive ones that sound much worse. "
Product type | Speakers |
Speaker type | Bookshelf speaker |
Power | Nominal : 80W RMS Max : 110W |
Number of way | 2 |
Number of speakers | 2 |
Sensitivity | 88dB |
Bandwidth | 55Hz - 20kHz |
Tweeter | 25mm, soft dome |
Medium / Woofer | 13cm, fiberglass |
Impedance | Min. 5Ω |
Cutoff frequency | 3000Hz |
Bass Reflex | Front laminar vent |
Binding post type | Screw bind post. Banana plugs compatible. |
Dimensions (LxHxP) | 16.5 x 27 x 20cm |
Weight / speaker | 3.1kg |
Finition and color | Dark Ash |
Quantity | Sold per pair (2 speaker) |
Color | Black |
Impedance (Ω) | 5 |
Efficiency / Sensitivity (dB) | 88.0 |
Lowest frequency (Hz) | 55 |
Highest frequency (Hz) | 20000 |
Power (W) | 80.0 |
Number of ways | 2 |
Number of loudspeakers | 2 |
