Portable DAC ES9281AC Pro USB-C 32bit 384kHz DSD256 MQA
This small FiiO KA1 portable DAC is small only in size. It offers excellent audio performance, thanks to high quality components that allow it to support high sampling rates while revealing a rich, detailed and dynamic sound. An ideal companion for anyone who wants to improve the sound quality of a smartphone or even a computer.
With dimensions of only 40x15x8mm, one might think that the available space is quite meager to offer a quality audio device. For the FiiO KA1 not only integrates a high-end DAC, but also embeds a powerful amplification circuit, each element being meticulously optimized by the brand's engineers. The KA1 is thus able to reproduce your music with great fidelity.
At the heart of the KA1 is an ESS ES9281AC Pro digital-to-analog conversion chip, combining a USB audio interface, DAC and amplifier in a single chipset. Combined with a gold-plated multi-layer HDI PCB, the result is very low crosstalk, high efficiency with low power consumption and pure sound reproduction.
The intelligent design of the FiiO KA1 allows it to support high sampling rates for the most detailed sound reproduction possible. It supports PCM streams up to 32bit 384kHz, native DSD up to DSD256 and DSD DoP up to DoP128.
The FiiO KA1 is also officially MQA (Master Quality Authenticated) certified. It is therefore fully capable of rendering this type of file, allowing to enjoy a sound as close as possible to the original studio recording, while keeping a limited file size. This is particularly good news for owners of a TIDAL account, the famous streaming platform offering this format for audiophile listening.
On the front panel, the KA1 displays a circular RGB LED indicator. This one displays in real time the type of file being played, according to the following color code:
| Specifications | |
| Product type | Portable DAC |
| DAC Chip | ESS ES9281AC Pro |
| Input | 1x Male USB-C |
| Output | 1x Female Jack 3.5mm |
| Supported sampling rates | PCM up to 32bit 384kHz Native DSD up to DSD256 DSD DoP up to DoP128 MQA |
| Channel balance | < 0.05dB (32Ω, THD+N < 1%) |
| Output power | 43mW @ 16Ω, THD+N < 1% 45mW @ 32Ω, THD+N < 1% 13mW @ 300Ω, THD+N < 1% 6.8mW @ 600Ω, THD+N < 1% |
| Output amplitude | 1.2V @ 32Ω, THD+N < 1% |
| Channel separation | ≥ 73dB @ 1kHz, 32Ω |
| Output impedance | < 1.5Ω |
| Frequency response | 20Hz - 20kHz (amplitude curve varying by 0.1dB) 20Hz - 50kHz (amplitude curve varying by 0.3dB) |
| SNR | ≥ 114dB @ 32Ω, A-Weighted |
| THD+N | 0.0005% |
| General | |
| Dimensions | 40 x 15 x 8mm |
| Cable length | ~ 70mm |
| Weight | 10g |
| Color | Black |
| Package | 1x FiiO KA1 1x Female USB-C to male USB-A adapter |
| Input | USB |
| Output | Jack 3.5mm |
| DAC / ADC Chip | ES9281AC |
| Max sampling rate | 384kHz |
| Max sampling rate | MQA |
| Max sampling rate | DSD256 |
| Color | Black |
| Networking | No |
| Remote Control | No |
