IBASSO D16 Portable USB DAC Headphone Amplifier
The IBASSO D16 is a portable USB DAC with integrated headphone amplifier positioned as a flagship audiophile model. It stands out with a fully discrete design based on 128 PWM-DACs (1-bit conversion) driven by a proprietary FPGA-Master 2.0, replacing conventional DAC chips. Hi-Res Audio compatible, it supports streams up to PCM 32bit / 768kHz and native DSD512, ensuring extremely precise and natural sound reproduction.
By buying this product you get 149 loyalty points
Reference : 21830
1 490,00 €tax incl.
1 241,67 € tax excl.
iBasso D16 Portable USB DAC Headphone Amplifier Class A Discrete 1-bit 32bit 768kHz DSD512
Photo of the IBASSO D16
The iBasso D16 is a portable USB DAC with integrated headphone amplifier positioned as a flagship audiophile model. It stands out with a fully discrete design based on 128 PWM-DACs (1-bit conversion) driven by a proprietary FPGA-Master 2.0, replacing conventional DAC chips. Hi-Res Audio compatible, it supports streams up to PCM 32bit 768kHz and native DSD512, ensuring extremely precise and natural sound reproduction.
Its amplification section is based on a discrete Class A circuit derived from the DX320MAX, capable of delivering high power reaching approximately 1125mW per channel at 32Ω, with substantial current to drive demanding headphones.
The D16 offers comprehensive connectivity with USB, coaxial and optical 3.5mm inputs, as well as headphone and line outputs in 3.5mm single-ended and 4.4mm balanced. It also features a 1.3" OLED display, stepped volume control, and physical controls for standalone operation.
Powered by an internal battery providing up to 9 hours of autonomy, it combines extreme performance and portability in a premium compact chassis.
iBasso D16: discrete 1-bit architecture (128 PWM-DACs driven by FPGA)
The D16 abandons traditional integrated DACs in favor of a fully discrete approach based on 128 PWM converters operating in parallel. This architecture is driven by the FPGA-Master 2.0, which handles signal processing, reclocking, and digital-to-analog conversion.
This discrete 1-bit operation achieves extremely low distortion levels (below 0.0001%) as well as more natural sound reproduction, with improved harmonic density and greater precision in micro-details.
Thanks to its advanced architecture, the D16 supports the most demanding audio formats on the market. It handles PCM streams up to 32bit 768kHz as well as native DSD512, ensuring full compatibility with modern high-resolution files.
This capability allows faithful reproduction of studio recordings, with high temporal precision and a particularly detailed soundstage.
IBASSO D16: discrete 1-bit architecture (128 PWM-DACs driven by FPGA)
iBasso D16: discrete Class A amplification
The D16 integrates a fully discrete Class A headphone amplifier, directly inspired by the DX320MAX design. This topology prioritizes linearity and sound quality over efficiency, delivering richer and more organic sound reproduction.
With power exceeding 1W per channel at 32Ω, along with high current capability, it can drive both in-ear monitors and high-impedance audiophile headphones. This power reserve ensures excellent dynamics and optimal control of the drivers.
IBASSO D16: discrete Class A amplification
iBasso D16: OLED display and precise control
The D16 features a 1.3-inch OLED display showing essential information such as volume, audio format, and active settings. It is paired with a stepped volume control ensuring greater precision and better gain management.
Physical buttons allow navigation through settings and fully standalone operation without relying on an external application.
IBASSO D16: OLED display and precise control
iBasso D16: extensive connectivity (USB, coaxial, optical and balanced outputs)
The D16 stands out with particularly comprehensive connectivity for a portable device. It offers multiple digital inputs: USB, coaxial, and optical, allowing use with a wide range of sources (smartphone, computer, digital transport).
On the output side, it features both headphone and line outputs in 3.5mm single-ended and 4.4mm balanced formats, providing flexibility and maximum performance depending on the equipment used.
IBASSO D16: extensive connectivity (USB, coaxial, optical and balanced outputs)
Technical specifications
Product typePortable DAC with integrated headphone amplifier
DAC128 PWM-DACs (1-bit conversion)
ControllerFPGA-Master 2.0
Class A amplification20 dual Low VCEsat transistors (BISS)
Inputs1x USB-C
1x Coaxial or optical input via 3.5mm jack
Outputs1x 3.5mm headphone/line jack output
1x 4.4mm balanced headphone/line jack output
Supported sample ratesVia USB-C input: PCM 32bit 768kHz and DSD512
Via coaxial 3.5mm jack input: PCM 32bit 768kHz and DSD DoP256
Via optical 3.5mm jack input: PCM 24bit 192kHz and DSD DoP128
DisplayOLED 1.3"
3.5mm headphone output measurements (PO)
Output level2.1Vrms (AMP low gain + DAC high gain)
3.4Vrms (AMP high gain + DAC high gain)
Output power640mW + 640mW @ 16 ohm THD+N <0.5%
THD+N-114dB (0.00019%) @ 1kHz
AES17-20K A-WT 600 ohm load
DNR118dB AES17-20K A-WT
SNR118dB AES17-20K A-WT
Crosstalk130dB
Frequency response15Hz-40kHz +/-1dB
4.4mm headphone output measurements (PO)
Output level4.2Vrms (AMP low gain + DAC high gain)
6.8Vrms (AMP high gain + DAC high gain)
Output power1125mW + 1125mW @ 32 ohm THD+N <0.5%
THD+N-117dB (0.00014%) @ 1kHz
DNR123dB AES17-20K A-WT
SNR123dB AES17-20K A-WT
Crosstalk131dB
3.5mm line output measurements (LO)
Output level1.65Vrms (DAC low gain)
2Vrms (DAC high gain)
THD+N-118dB (0.00012%) @ 1kHz
AES17-20K A-WT
DNR120dB AES17-20K A-WT
SNR120dB AES17-20K A-WT
Crosstalk133dB
4.4mm line output measurements (LO)
Output level3.3Vrms (DAC low gain)
4Vrms (DAC high gain)
THD+N-120.4dB (0.000095%) @ 1kHz
AES17-20K A-WT
Crosstalk135dB
Power supply5V 2A via USB-C (QC3.0 compatible)
Battery charging time2.5h
Battery life9h
Dimensions139x82x28mm
Weight312g
Packaging1x iBasso D16
1x Protective case
1x USB-C OTG cable
1x USB-C to Lightning OTG cable
1x 3.5mm coaxial cable
1x 3.5mm mini Toslink optical cable
InputMini Toslink 3.5mm
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipPWM
Max sampling rate768kHz
Max sampling rateDSD512
IBASSO D16 Portable USB DAC Class A Headphone Amplifier 1bit Discrete 32bit 768kHz DSD512
The IBASSO D16 is a portable USB DAC with integrated headphone amplifier positioned as a flagship audiophile model. It stands out with a fully...
