KIWI EARS ALLEGRO BAL Portable DAC Headphone Amplifier
The KIWI EARS ALLEGRO BAL is a portable balanced USB-C DAC headphone amplifier designed to deliver high-resolution audio in an ultra-compact form factor. Equipped with a next-generation DAC/headphone amplifier chip, it supports PCM audio streams up to 32bit / 384kHz, allowing you to take full advantage of high-definition audio files. Its balanced output delivers 180mW + 180mW into 32Ω (360mW total), providing enough power to drive the vast majority of in-ear monitors as well as many headphones.
Reference : 22370
49,90 €tax incl.
41,58 € tax excl.
KIWI EARS ALLEGRO BAL Portable Balanced USB-C DAC Headphone Amplifier 32bit 384kHz
It also offers excellent audio performance with a signal-to-noise ratio of ≥113dB, crosstalk below -100dB, THD+N below 0.005%, and an ultra-low noise floor of just 5μV, ensuring precise, detailed, and silent audio reproduction. Its CNC-machined aluminum enclosure provides excellent durability while promoting efficient heat dissipation. The 90° angled design minimizes bulk when connected to the USB-C port of a smartphone, tablet, laptop, or compatible gaming console, making it a powerful, discreet, and highly practical portable DAC and headphone amplifier for enjoying Hi-Res audio with a wide soundstage, precise treble, and deep bass.
Technical Specifications
Product typePortable DAC / Headphone amplifier
Input1x USB-C Male
Output1x 4.4mm balanced jack output
Output powerL+R ≥ 180mW + 180mW (32Ω, THD+N < 1%)
SNR≥ 113dB (32Ω load / A-weighted)
THD+N< 0.005% (−6dBFS @ 32Ω load)
Crosstalk< −100dB (32Ω load)
Noise floor5μV
ColorSilver
Package contents1x Kiwi Ears Allegro BAL
OutputJack 4.4mm
DAC / ADC ChipNC
Max sampling rate384kHz
ColorSilver
KIWI EARS ALLEGRO BAL Portable Balanced DAC Headphone Amplifier USB-C 32bit 384kHz
The KIWI EARS ALLEGRO BAL is a portable balanced USB-C DAC headphone amplifier designed to deliver high-resolution audio in an ultra-compact form...
