MOONDROP FREEDSP MINI Adapter DAC USB-C / Jack 3.5mm
The Moondrop FreeDSP Mini is a compact USB DAC with integrated DSP, designed to improve the sonic performance of earphones. It features a CS43198 DAC chip paired with a DSP processor, allowing optimization of frequency response and sound signature according to listening preferences. Capable of handling audio streams up to PCM 32bit 768kHz and DSD256, it ensures precise conversion and faithful reproduction with a 127dB dynamic range and ultra-low distortion (0.00017% THD+N).
Reference : 21544
34,90 €tax incl.
29,08 € tax excl.
Moondrop FreeDSP Mini USB-C Male to 3.5mm Female DAC Adapter CS43198 32bit 384kHz DSD256
Photo of the MOONDROP FREEDSP MINI
Equipped with a USB-C to 3.5mm female jack connection, it functions as an active digital audio cable for smartphones, tablets, and computers. It delivers a maximum output power of 2x80mW at 16Ω, allowing demanding earphones to perform at their full potential. Ideal for mobile or portable audiophile use, the FreeDSP Mini unlocks the full capability of your IEMs while providing advanced sound control.
Moondrop FreeDSP Mini: High-Precision DAC & Programmable DSP
The FreeDSP Mini’s CS43198 DAC supports PCM up to 32bit 768kHz and DSD256. In addition, a free DSP interface is accessible via the Moondrop Android application, allowing users to adjust filter type, frequency points, gain, and Q values. A comprehensive headphone frequency response database is also available as a reference during tuning. DSP adjustment can also be performed via the web interface, offering a more professional, complete, and precise environment than the mobile application.
The Moondrop Web and Android applications are updated simultaneously, eliminating the need for manual adjustments. Users can simply select or upload original frequency curves and target responses for one-click application, enabling deeper sound customization.
MOONDROP FREEDSP MINI: High-Precision DAC & Programmable DSP
Moondrop FreeDSP Mini: High-Efficiency Performance
Thanks to its high-performance decoding chip and LDO-based design, the FreeDSP Mini achieves a dynamic range of up to 127dB and total harmonic distortion as low as 0.00017%, with a maximum output power of 2x80mW at 16Ω.
MOONDROP FREEDSP MINI: High-Efficiency Performance
Moondrop FreeDSP Mini: USB-C Plug-and-Play & CTIA Headset Support
Featuring a USB-C interface, the FreeDSP Mini connects easily to smartphones, computers, and tablets. It delivers superior sound quality compared to standard USB-C earphones while eliminating latency and signal degradation.
The FreeDSP Mini supports CTIA-standard wired microphones, making it ideal for calls, live streaming, gaming and more when paired with compatible headsets such.
MOONDROP FREEDSP MINI: USB-C Plug-and-Play & CTIA Headset Support
Technical Specifications
Product typeDAC adapter with DSP
DAC chipCS43198
Input1x USB-C
Output1x 3.5mm female jack (4-pin CTIA: SE + MIC)
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
Dynamic range127dB @ 1kHz
THD+N (A-wt)0.00017% @ 1kHz
Output level2Vrms @ 0dBFS
Output power2x80 mW @ 16Ω (THD+N < 1%)
Dimensions13 × 13 × 1.7cm
Weight106g
Package contents1x Moondrop FreeDSP Mini
Moondrop FreeDSP Mini measurements
OutputJack 3.5mm
DAC / ADC ChipCS43198
Max sampling rateDSD256
Max sampling rate768kHz
MOONDROP FREEDSP MINI Adapter DAC USB-C Male to Jack 3.5mm Female CS43198 32bit 384kHz DSD256
The Moondrop FreeDSP Mini is a compact USB DAC with integrated DSP, designed to improve the sonic performance of earphones. It features a CS43198...
