QUESTYLE Q-LINK DAC Adapter
The Questyle Q-Link is a compact USB DAC designed to ensure digital-to-analog conversion on the go, relying on a CX31993 chip to support PCM streams up to 32 bit / 384 kHz. Beyond this conversion foundation, its architecture prioritizes an optimized connection through a cable integrating 8 pure silver conductors, reducing losses and interference while maintaining signal integrity, while the aluminum-bodied connectors ensure consistent mechanical durability. This approach extends to broad compatibility, including with Apple devices, allowing direct use without specific configuration.
Reference : 22040
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 24-11-2026.
Questyle Q-Link DAC Adapter USB-C to 3.5mm Jack CX31993 32bit 384kHz
Questyle Q-Link: Front view
The Questyle Q-Link is a compact USB DAC designed to ensure digital-to-analog conversion on the go, relying on a CX31993 chip to support PCM streams up to 32bit 384kHz. Beyond this conversion foundation, its architecture prioritizes an optimized connection through a cable integrating 8 pure silver conductors, reducing losses and interference while maintaining signal integrity, while the aluminum-bodied connectors ensure consistent mechanical durability. This approach extends to broad compatibility, including with Apple devices, allowing direct use without specific configuration.
Product typePortable DAC
Input1x USB-C male
Output1x 3.5mm jack
DAC chipCX31993
Supported sampling ratesPCM 32bit 384kHz
Output power28mW @ 32Ω
Total harmonic distortion (THD)-95dB
Signal-to-noise ratio100dB
Crosstalk-80dB
Total length118mm
Weight5g
PackageSold individually
OutputJack 3.5mm
DAC / ADC ChipCX31993
Max sampling rate384kHz
ColorSilver
QUESTYLE Q-LINK DAC Adapter USB-C to 3.5mm Jack CX31993 32bit 384kHz
The Questyle Q-Link is a compact USB DAC designed to ensure digital-to-analog conversion on the go, relying on a CX31993 chip to support PCM...
