très bel étui, très bonne qualité, conforme à la description et convient à merveille au Dac ONIX ALPHA XI1 DAC
Shanling unveils its Onix Alpha XI1, a balanced portable DAC featuring high-quality components. It incorporates two CS43198 DAC chips, enabling it to support high-resolution sampling rates up to PCM 32bit 384kHz and native DSD up to DSD256 via its USB input. It also features two SGM8262 headphone amplifiers for a substantial power reserve, enabling it to drive a large number of IEMs and headphones available on the market. In fact, it offers output power of up to 180mW on its 3.5mm jack output, and up to 500mW at 32 ohms on its balanced 4.4mm jack output. Simple to use, 3 buttons provide access to main controls such as volume control and play/pause function. Added to this is a small 0.87-inch display with a pleasant interface for simplified navigation and display of essential information.
The two Cirrus Logic CS43198 DAC chips in the Shanling Onix Alpha XI1 portable DAC enable it to support 32bit 384kHz PCM streams, as well as native DSD up to DSD256 via its USB-C input. The two DAC chips work in balanced mode for clear, precise sound reproduction.
Two SGM8262 operational amplifiers take care of the headphone amplification. These low-noise, low-distortion operational amplifiers provide adequate output power for the Onix Alpha XI1 portable DAC, with up to 180mW on its 3.5mm jack output and up to 500mW at 32 ohms on its balanced 4.4mm jack output. This enables it to drive a wide range of headphones and earphones. The 0.4/0.8 ohm output impedance of the Onix Alpha XI1 contributes to its high level of compatibility.
The Eddict Player application lets you easily control the Onix Alpha XI1. It offers the possibility of adjusting the sound rendering thanks to 5 filters.
Despite its compact form factor, the Onix Alpha XI1 portable DAC features a small 0.87-inch screen for easy navigation and display of essential information. This is complemented by 3 buttons for volume control and play/pause.
Product type | Portable DAC Portable Headphone Amplifier |
DAC chip | 2x CS43198 |
Headphone amplification | 2x SGM8262 |
Inputs | USB-C |
Outputs | 1x Single-ended 3.5mm jack 1x Balanced 4.4mm jack |
Supported sample rates | PCM up to 32bit 384kHz DSD up to DSD256 |
Output power | 3.5mm jack: 180mW 4.4mm jack: 500mW |
Display | 0.84" |
Single-ended 3.5mm jack output | |
THD+N | 0.0004% @ 32Ω (A-weighted @ 2V) |
Dynamic range | 125dB @ 32Ω (A-weighted) |
Channel separation | 71dB @ 32Ω |
SNR | 126dB @ 32Ω |
Output impedance | 0.4Ω |
Balanced 4.4mm jack output | |
THD+N | 0.0005% @ 32Ω (A-weighted @ 2V) |
Dynamic range | 129dB @ 32Ω |
Channel separation | 99dB @ 32Ω |
SNR | 129dB @ 32Ω |
Output impedance | 0.8Ω |
Dimensions | 64 x 32 x 14mm |
Color | Black |
Weight | 37.8g |
Package | 1x Shanling Onix Alpha XI1 Portable DAC |
Input | USB |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
DAC / ADC Chip | CS43198 |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | Black |
Class | N/A |
Networking | No |
Remote Control | No |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Franck M.
Étienne F.
Nordine K.
Wissem B.
