SHANLING ONIX BETA XI2 Portable DAC Tube Headphone Amplifier
With the Onix Beta XI2, Shanling presents the new version of their successful portable DAC. This new iteration retains the dual CS43198 DAC architecture that made its predecessor famous and combines it with JAN6418 tube amplification for a warm and smooth sound, typical of analogue.
By buying this product you get 34 loyalty points
Reference : 21159
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 01-05-2026.
Shanling Onix Beta XI2 Portable DAC Tube Headphone Amplifier CS43198 32bit 768kHz DSD512
Shanling Onix Beta XI2 : Front view
Shanling Onix Beta XI2: 2 CS43198 DAC chips
The Onix Beta XI2 uses two Cirrus Logic CS43198 DAC chips, enabling it to support data streams up to PCM 32-bit 768kHz and DSD512. The two DAC chips work symmetrically to deliver clear and accurate sound reproduction.
Shanling Onix Beta XI2 : DAC chip
Shanling Onix Beta XI2 : TPA1612 tubes
Shanling Onix Beta XI2: Power tubes and OPA1612
The amplification stage of the ONIX Beta XI2 is based on a pair of OPA1612 op-amps coupled with BUF434A and JAN6418 power tubes. These tubes are renowned for their compact size, low power consumption and stable operation. The use of tubes provides warm, smooth sound reproduction. However, if you prefer more neutral reproduction with more pronounced dynamics, a transistor amplification mode is also available.
Shanling Onix Beta XI2: Aluminium housing
The Beta XI2 retains the characteristic aesthetics of the ONIX range and features a CNC-machined aluminium body combined with a 0.78-inch screen and three physical buttons for volume and playback control.
Shanling Onix Beta XI2 : Side view
Product typePortable DAC and headphone Amplifier
Input1x USB-C
Outputs1x Balanced 4.4mm headphone jack output
1x Single-ended 3.5mm headphone jack output
DAC chips2x CS43198
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Amplification components2x JAN6418
2x TPA1612
4x BUF434A
Screen0.87 inch
USB modeUAC 1.0
UAC2.0
Single-ended 3.5mm jack output (Transistors)
Output powerLow gain : 45mW @ 32Ω
High gain : 180mW@ 32Ω
Total harmonic distortion more noise (THD+N)0.0006% @ 32Ω (A-Weight)
Dynamic range124dB @ 32Ω (A-Weight)
Channel Separation73dB
Signal-to-noise ratio (SNR)124dB @ 32Ω (A-Weight)
Output impedance0.3Ω
Single-ended 3.5mm jack output (Tubes)
Output powerLow gain : 37mW @ 32Ω
High gain : 152mW @ 32Ω
Total harmonic distortion more noise (THD+N)0.006% @ 32Ω (A-Weight)
Dynamic range122dB @ 32Ω (A-Weight)
Signal-to-noise ratio (SNR)122dB @ 32Ω (A-Weight)
Balanced 4.4mm jack output (Transistors)
Output powerLow gain : 180mW @ 32Ω
High gain : 550mW @ 32Ω
Total harmonic distortion more noise (THD+N)0.0008% @ 32Ω (A-Weight)
Dynamic range128dB @ 32Ω (A-Weight)
Channel Separation107dB
Signal-to-noise ratio (SNR)128dB @ 32Ω (A-Weight)
Output impedance0.6Ω
Balanced 4.4mm jack output (Tubes)
Output powerLow gain : 152mW @ 32Ω
Dynamic range127dB @ 32Ω (A-Weight)
Signal-to-noise ratio (SNR)127dB @ 32Ω (A-Weight)
Dimension69.8 x 39 x 14mm
Weight45.3g
Package1x Shanling Onix Beta XI2
1x USB-C to USB-C cable
1x USB-C to USB-A adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD512
ClassTube amp
SHANLING ONIX BETA XI2 Portable DAC Tube Headphone Amplifier CS43198 32bit 768kHz DSD512
With the Onix Beta XI2, Shanling presents the new version of their successful portable DAC. This new iteration retains the dual CS43198 DAC...
