FIIO SNOWSKY MELODY Portable DAC Headphone Amplifier Maple
The FiiO Melody is a small, portable USB DAC and headphone amplifier with a unique design and an attractive wooden housing. Its digital-to-analog conversion stage is equipped with two CS43131 DAC chips, enabling it to support sampling rates up to PCM 32-bit 384 kHz and DSD256.
Reference : 21181
49,00 €tax incl.
40,83 € tax excl.
Shipping date: 24-11-2026.
FiiO Snowsky Melody Portable DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Maple
FiiO Melody
The Melody's input is via a USB-C connector and the output is either via an single-ende d3.5mm jack or a balanced 4.4mm jack. The 3.5mm jack output also supports coaxial SPDIF and is compatible with wired controls and microphones. In addition, the Melody is compatible with the FiiO Control app, which includes a 10-band parametric equalizer.
The headphone amplifier stage of the FiiO Melody delivers 2x100mW of power into 32Ω on its unbalanced 3.5mm jack output and 2x250mW into 32Ω on its balanced 4.4mm jack output.
The Melody is equipped with two side buttons for controlling volume and skipping to the next/previous track. In addition, one of the buttons is equipped with an LED indicator for the sampling rate.
The FiiO Melody's microprocessor helps deliver excellent sound quality while limiting the device's power consumption and heat generation. When playback stops, the Melody goes into standby mode and its power consumption drops below 10mA. This means it won't drain the battery of your smartphone or DAP when not in use.
FiiO Melody : Key features
Product typePortable DAC and headphone amplifier
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm / Coaxial combo
1x Balanced Jack 4.4mm
DAC chips2x CS43131
USB interfaceSPV5048
DSD up to DSD256
Coaxial: PCM up to 32bit 384kHz
Adaptive impedanceSingle-ended: 16~150Ω
Balanced: 16~300Ω
Firmware updateVia USB
Control appFiiO Control
CompatibilityAndroid
iOS
Windows
Mac
UAC supportUAC 1.0
UAC 2.0
Single-ended Jack 3.5mm headphone output performances
Output power≥ 2x116mW @ 16Ω, THD+N < 1%
≥ 2x100mW @ 32Ω, THD+N < 1%
≥ 2x13mW @ 300Ω, THD+N < 1%
Frequency response20Hz~20kHz, attenuation ≤ 0.1dB
20Hz~50kHz, attenuation ≤ 0.2dB
THD+N< 0.00066% (0dB, 32Ω)
Max output voltage≥ 2.3V (32Ω, THD+N < 1%)
Output impedance< 0.9Ω
Crosstalk≥ 76dB (1kHz, 32Ω)
SNR≥ 123dB (32Ω, A-wt)
Balanced Jack 4.4mm headphone output performances
Output power≥ 2x127mW @ 16Ω, THD+N < 1%
≥ 2x250mW @ 32Ω, THD+N < 1%
≥ 2x54mW @ 300Ω, THD+N < 1%
20Hz~50kHz, attenuation ≤ 0.1dB
THD+N< 0.0003% (0dB, 32Ω)
Max output voltage≥ 4V (32Ω, THD+N < 1%)
Output impedance< 1Ω
Crosstalk≥ 121dB (1kHz, 32Ω)
SNR≥ 127dB (32Ω, A-wt)
Dimensions42 x 22.5 x 11.5mm
Weight~ 10g
ColorMaple
Package1x FiiO Melody
1x USB-C cable
OutputJack 3.5mm
OutputJack 4.4mm
OutputCoaxial SPDIF
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorWood
ColorÉrable
ClassN/A
Exellent, mais...
J’ai eu l’occasion de tester ce dac. Il est exellent. Neanmoins , avec des audios losless sur spotify ET sur mon samsung s24 ultra, il génère du souffle. Dommage!
Un peu moins de souffle avec tablette xiaomi pad 7 pro
This review has been posted for FIIO SNOWSKY MELODY Portable DAC Headphone Amplifier 2x CS43131 32bit 384kHz DSD256 Maple
The FiiO Melody is a small, portable USB DAC and headphone amplifier with a unique design and an attractive wooden housing. Its digital-to-analog...
