SHANLING UP6 Portable DAC Headphone Amplifier Grey
New
With the UP6, Shanling presents a portable balanced headphone DAC and amplifier based on two ESS ES9069Q chips and two SGM8262 OPAs to offer conversion up to PCM 32bit 768kHz and DSD512 and an output power of 195mW at 32Ω single-ended and 626mW at 32Ω balanced.
Reference : 20701
189,00 €tax incl.
157,50 € tax excl.
Shanling UP6 Portable DAC Headphone Amplifier 2xES9060Q 32bit 768kHz DSD512 Bluetooth 5.2 Grey
Shanling UP6 : Front view
Shanling UP6: ESS ES9069Q Dual DAC
In order to offer the best possible listening experience, the UP6's digital/analogue conversion stage is based on a pair of ESS ES9060Q DAC chips. These top-of-the-range DACs process signals up to a sampling rate of 32bit 768kHz in PCM and DSD512. Furthermore, the ESS chips have a -120dB harmonic distortion and an impressive dynamic range of 130dB, ensuring that even the most complex musical compositions are accurately converted.
Shanling UP6 : Dual ESS DAC chip
Shanling UP6 suspended in the air
Shanling UP6: SGM8262 dual amplification chip
To accompany the UP6's excellent converter stage, it incorporates two SGM262 OPAs, delivering an output power of 195mW at 32Ω single-ended and 626mW at 32Ω balanced. This more than impressive power output means that the UP6 can easily drive even the most power-hungry headphones and earphones.
Shanling UP6: Qualcomm QCC5125 Bluetooth chip
To provide the best possible connectivity, the UP6 is equipped with a Qualcomm QCC5125 Bluetooth chip supporting LDAC, aptX HD, aptX Adaptive, apt-X LL, aptx, AAC and SBC protocols.
Shanling UP6 connected via USB to a telephone
Shanling UP6 : XMOS chips
Shanling UP6: Interface USB XMOS XU316
To ensure that it can be connected via USB while taking full advantage of the capabilities of the ESS DAC chips, the UP6 incorporates an XMOS XU316 interface, which when coupled with two KDS crystal oscillators, supports a signal up to 32bit 768kHz PCM and DSD512.
Shanling UP6: A wide range of functions
The UP6 incorporates a host of different functions to suit every situation. For example, you'll find :
  • A mono DAC mode when used in Single-ended mode, allowing battery backup.
  • A car mode enabling it to switch on and off at the same time as your car.
  • A UAC 1.0 mode for compatibility with older devices such as games consoles.
  • An integrated SiSonic microphone with noise cancellation for clean phone calls.
  • Simple pairing thanks to NFC support.
Shanling UP6: Eddict player application
To control the many features of the UP6, such as managing Bluetooth codecs, customising the equalisation or updating the firmware, you can download the Eddict Player app, available on Android and iOS.
Shanling UP6: 950mAh battery
To ensure trouble-free use on the move, the UP6 has a 950mAh battery, enabling it to be used for up to 6.5 hours without interruption.
Shanling UP6 connected by Bluetooth
Product typePortable DAC
Mobile headphone amplifier
Input1x USB-C
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
DAC chips2x ES9069Q
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Amplification chips2x SGM8262
USB interfaceXMOS XU316
Bluetooth module1x QCC5125
Bluetooth Version5.2
Bluetooth CodecsLDAC, aptX HD, aptX Adaptive, apt-X LL, aptx, AAC, SBC
Battery capacity950mAh
AutonomySingle-ended: 6.5h
Balanced: 4.5h
Time to recharge2h
Recommended charger5V DC / 500mA
Single-ended 3.5 mm Jack output
Power output (Mono DAC mode)Low gain: 45mW @ 32Ω
High gain: 180mW @ 32Ω
Output power (Dual DAC mode)Low gain: 48mW @ 32Ω
High gain: 195mW @ 32Ω
Frequency response20Hz-40kHz (-0.5dB)
Total harmonic distorsion more noise (THD+N)0.0008%
Dynamic range123dB
Channel separation75dB
Signal-to-noise ratio (SNR)124dB
Background noise115dB
Output impedance< 1Ω
Balanced 4.4 mm Jack output
Power outputLow gain: 155mW @ 32Ω
High gain: 626mW @ 32Ω
Dynamic range128dB
Signal-to-noise ratio (SNR)128dB
Background noise119dB
Output impedance1.2Ω
Dimensions70 x 39 x 14mm
Weight51g
ColorGrey
Package1x Shanling UP6
1x USB-A to USB-C cable
1x USB-C to USB-C cable
1x USB-A to USB-C adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipES9060Q
Max sampling rateDSD512
Max sampling rate768kHz
ColorGray
ClassN/A
SHANLING UP6 Portable DAC Headphone Amplifier 2xES9060Q Bluetooth 5.2 32bit 768kHz DSD512 Grey
With the UP6, Shanling presents a portable balanced headphone DAC and amplifier based on two ESS ES9069Q chips and two SGM8262 OPAs to offer...
