AUDIOPHONICS HPA-S300NIL Power Amplifier Nilai500DIY
AUDIOPHONICS HPA-S300NIL Power Amplifier Class D Stereo Nilai500DIY 2x300W 4 Ohm
Hand-assembled in our workshop in France, the Audiophonics HPA-S300NIL power amplifier is a high-performance stereo model, based on the new Hypex Nilai500DIY amplification solution. This delivers high power output with very low noise and distortion, for clear, precise sound reproduction. These modules are combined with a specially designed power supply, the Hypex PS500DIY, providing audio circuits with a clean, stable electrical signal.
By buying this product you get 169 loyalty points
Reference : 18102
1 690,00 €tax incl.
1 408,33 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been upgraded to a fully dual-mono version, the Audiophonics HPA-DM500NIL.
Audiophonics HPA-S300NIL Power Amplifier Class D Stereo Nilai500DIY 2x300W 4 Ohm
Hand-assembled in our workshop in France, the Audiophonics HPA-S300NIL power amplifier is a high-performance stereo model, based on the new Hypex Nilai500DIY amplification solution. This delivers high power output with very low noise and distortion, for clear, precise sound reproduction. These modules are combined with a specially designed power supply, the Hypex PS500DIY, providing audio circuits with a clean, stable electrical signal. The whole unit is housed in a solid, sand-blasted aluminum case, revealing both a massive, modern design and perfect heat dissipation.
Audiophonics HPA-S300NL Amplificateur de Puissance Class D Stéréo Nilai500DIY 2x300W 4Ω
Dual Nilai500DIY modules
Each channel of the Audiophonics HPA-S300NIL features its own Class D Hypex Nilai500DIY amplifier module. These, integrated in a stereo architecture, ensure exceptional sonic performance, and enable the development of significant power, with no less than 300W per channel at 4Ω. Each module features high-end components, including a totally discrete buffer stage and high-quality voltage regulators, as well as a brand-new control loop technology. The result is a drastic reduction in distortion, noise and output impedance, enabling the HPA-S300NIL to reveal a rich, precise sound with a wide soundstage.
PS500DIY Power supply
The Nilai500DIY modules are combined with a specially designed Hypex PS500DIY switch mode power supply. This features audiophile-grade components and PFC (Power Factor Correction) to ensure high power density and a significant reduction in EMI interference conductivity. The module also incorporates a complete protection system for enhanced device durability.
Switchable RCA and XLR inputs
The HPA-S300NIL features dual input connectors with two RCA ports (dual mono single-ended) and two XLR ports (dual mono balanced). The RCA connectors are 24k gold-plated with heat-resistant plastic caps. The XLR connectors are from Neutrik, and feature a high-quality design with metal locking latch.
A two-position selector switch makes it easy to alternate between XLR and RCA inputs. So you can connect two different preamplifiers and alternate input sources.
High-quality speaker terminal blocks
The Audiophonics HPA-S300NIL features two pairs of 24-carat gold-plated speaker terminals on the rear panel. These terminals are designed to accept banana plugs up to Ø4mm in diameter. They can also accommodate bare conductors thanks to a Ø5.3mm screw-lockable slot.
5-12V Trigger
A double trigger socket (input and output) brings the convenience of an automated and particularly practical power sequence to your entire audio system. The power input is via an IEC C14 socket. This is fitted with a 5x20mm 6.3A fuse (supplied and pre-installed).
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Effective heat dissipation
As a high-power amplifier, the HPA-S300NIL is, quite naturally, subject to thermal stress during use. Heat management is therefore of paramount importance, both to maintain amplification performance and to ensure excellent durability.
The chassis, entirely designed in sand-blasted aluminum, is equipped on its sides with two imposing radiators capable of efficiently dissipating heat. In addition, carefully distributed ventilation holes promote air circulation and heat dissipation. The heat sinks also contribute to the amplifier's solid, modern aesthetic.
Product typePower amplifier
Amplification typeClass D
Amplification modules2* Hypex Nilai500DIY
Channels2 (Stereo)
Inputs2* Single-ended RCA
2* Balanced XLR
Amplification technologyNilai
Output power2x300W @ 4Ω
2x250W @ 8Ω
THD+N0.0005% (20Hz<f<20kHz, 4Ω, P<100W)
SNR129.6dB
Output noise15µV
Frequency response0Hz - 70kHz
TriggerInput / Output
5-12VDC
Gain21.75dB
Supply voltage110-240V AC
Max electric consumption650W
Housing materialSandblaster aluminum
DimensionsWithout connectors: 413*330*60mm
With connectors: 413*360*60mm
Weight5.6kg
Package1* Audiophonics HPA-S300NIL
1* Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipHypex Nilai500DIY
Power (W)300.0
impressionnant
je viens de recevoir mon nouvel ampli made in audiophonics.
il est encore en rodage mais je dois dire que c'est "du lourd".
c'est la nouvelle version en double mono total avec deux nilai 500 et deux alim independantes.
la puissance n'a quasiment pas de limite. la definition est totale sur tout le spectre, jusqu'aux tres basses frequences.
Raccorde a mon nouveau streamer matrix (avec roon et qobuz) et aux enceintes Klipsch RF7, c'est top niveau.
bon, les RF7 montrent leurs limites et il va falloir s'occuper de cela prochainement mais pour la partie electronique, je suis pare pour un moment.
This review has been posted for AUDIOPHONICS HPA-S300NIL Power Amplifier Class D Stereo Nilai500DIY 2x300W 4 Ohm
Hand-assembled in our workshop in France, the Audiophonics HPA-S300NIL power amplifier is a high-performance stereo model, based on the new Hypex...
