AUDIOPHONICS MPA-S125NCX RCA Power Amplifier Class D Stereo NCore NCx122MP 2x125W 4 Ohm
The Audiophonics MPA-S125NC incorporates a Hypex Ncore NC122MP power amplifier module. This is a solid base to build a powerful stereo HiFi system, capable of delivering 2x75W under 8Ω.
4.8 / 5
By buying this product you get 39 loyalty points
Reference : 12756
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 20-11-2026.
Audiophonics Workshop amplifiers range
Audiophonics MPA-S125NCX RCA
Power amplifier NCoreX NCx122MP 2x75W 8Ω Black
Audiophonics MPA-S252NCX RCA Amplificateur Stéréo Class D Ncore 2x150W 8 Ohm
An amplifier with solid performance
The Audiophonics MPA-S125NCX incorporates a Hypex NcoreX NCx122MP power amplifier module.
On a single double-sided PCB it is composed of a low power supply for standby, a high-performance switching power supply but above all an extremely efficient Class D amplifier circuit.
The amplifier used on this NCx122MP module offers a high efficiency of 92% and allows it to be used for very different uses, whether for studio use or to be integrated into a high fidelity audio system.
The distinctive characteristics of this amplifier are its linear frequency response whatever the load impedance and consequently its accurate restitution, its very low distortion but also its very low EMI radiation rate.
The control of the amplifier is based on a self-oscillating loop with phase shift, taking into account the feedback only at the output of the loudspeaker, always with sound transparency in mind.
The main SMPS power supply to the amplifier is a regulated, high power, high efficiency half bridge converter with synchronous rectification on the main output rails. An ideal power supply to provide this Class D amplifier with the power it needs.
In order to be compatible with supply voltages of 100-120V and 200-240V, it is equipped with an automatic input voltage doubler.
POINTS CLÉS :
  • High efficiency
  • Load-independent flat frequency response
  • Low output impedance
  • Frequency-independant ultra low distorsion
  • Very low noise
Hypex NCx122MP
NCoreX Technology
NCoreX Class D amplifiers, a direct evolution of the NCoreX modules, come close to matching the performance of operational amplifiers while surpassing them in terms of sound quality. As a result, they are capable of delivering clear, rich, and musical sound while remaining compact.
This NCoreX technology combines the stability of Hypex UcD series amplifiers with lower distortion and output impedance.
100% Aluminium Housing
We integrate this Hypex NCoreX NCx122MP amplifier in a 100% black brushed aluminum housing.
This case offers an elegant finish, the thick walls give it a great resistance, allowing it to protect components properly.
The natural conduction of aluminium, together with a studied air flow, allows the heat produced by the module to be dissipated.
In addition, the case is screen printed on the front with the NCoreX logo and on the back with the nomenclature of each input/output.
Its very compact format with a small width reduces space to a minimum, thus offering high performance in a small space.
This amplifier is DC pass-through , there are no decoupling capacitors at the input.
Be sure that your source is DC free before use.
The DC protection triggers at 12V DC, which is a quite high value.
In addition to the usual connection system, there is a trigger input on the rear panel.
This 3.5mm jack input allows the module to be switched on with a DC voltage signal from 5 to 12V to synchronize it with a preamp having this type of output.
It is also possible to chain 2 amplifiers, and to switch on both simultaneously by controlling only one, the input being transformed into an output if the power button of one of the amplifiers is pressed.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Also present on the front is a diode relaying the status of the module, lighting up if a DC voltage is detected at the output.
Test Qobuz hypex PA s125 NC amp stereo Audiophonics
Discover the test by Qobuz
The MPA-S125NCX (previously PA-S125NC) was the subject of a test from Qobuz.
Click here to read it.
Amplifier typeClass D
Power2x75W 8Ω @ 1kHz THD=1%
2x125W 4Ω @1Khz THD=1%
2x 37W 8Ω @ 10Hz-20kHz THD=0.0015%
2x 62W 4Ω @ 10Hz-20kHz THD=0.0015%
THD+N0.0015%
SNR118dB
Output noise30µV
Frequency response10Hz - 50kHz
Efficiency92%
Gain25.5dB
Input sensibility125W 4ohm @ 1.17V RMS
Channels2 (Stereo)
TechnologyNCoreX
InputStereo RCA
Input / OutputTrigger 5-12V DC
OutputSpeaker connectors
Housing material100% brushed Aluminium
Power supplyMain : IEC (included cable)
Autoswitch (115 / 230V) US grid compatible
Trigger : Jack 3.5mm 12V (not included)
Total dimensions (WxDxH)145 x 355 x 64mm
Weight1310g
Power cableIncluded
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)75.0
37 reviews
Configuration Bi-Amping
J'utilise un amplificateur de puissance stéréo haut de gamme en Classe D, l'AUDIOPHONICS MPA-S250NCX RCA (équipé du module Hypex Ncore NCx252MP), exclusivement dédié au registre des graves. À l'origine, il était associé à un amplificateur intégré des années 90, le Yamaha AX-592, qui prenait en charge les médiums et les aigus.
Afin d'harmoniser parfaitement les niveaux de gain entre les deux voies de bi-amplification, j'utilise désormais également un AUDIOPHONICS MPA-S125NCX RCA pour le haut du spectre, et le Yamaha AX-592 ne me sert plus que de préamplificateur. C'est précisément cet équilibre tonal entre caractère et contrôle qui fait la magie de ce système : les modules Hypex NcoreX sont extrêmement neutres, rapides et insensibles aux variations de charge, mais ils pourraient paraître presque trop analytiques sur certaines enceintes. En utilisant le Yamaha AX-592 uniquement en préamplification, il n'est plus sollicité par les appels de courant du grave et apporte cette chaleur analogique et cette musicalité typiques des années 90, tout en laissant les NcoreX alimenter mes JBL L80 MKII avec une réserve de puissance et une facilité déconcertantes.
Comme source musicale, j'utilise Spotify Lossless depuis un Samsung S24, qui transmet le flux en LDAC (24 bits / 44,1 kHz) vers un récepteur Bluetooth 5.3 1Mii B06HD+ fonctionnant sur batterie, lui-même relié en analogique au reste de la chaîne.
Lors de la première écoute de cette association, j'ai été très agréablement surpris : pour obtenir un tel niveau de restitution sonore, la facture peut facilement grimper bien plus haut !
Cordialement depuis l'Allemagne, et un grand merci pour votre service irréprochable !
This review has been posted for AUDIOPHONICS MPA-S125NCX RCA Power Amplifier Class D Stereo NCore NCx122MP 2x125W 4 Ohm
Afin d'harmoniser parfaitement les niveaux de gain entre les deux voies de bi-amplification, j'utilise désormais également un AUDIOPHONICS MPA-S125NCX RCA pour le haut du spectre, et le Yamaha AX-592 ne me sert plus que de préamplificateur. C'est précisément cette signature sonore vintage des années 90 du Yamaha qui apporte cette belle touche de chaleur à l'ensemble. Quant à la réserve de puissance, elle est assurée par les modules Hypex NcoreX, qui alimentent mes enceintes JBL L80 MKII avec une facilité déconcertante.
There's a day-and-night difference between this amplifier and all the others on the TPA3255 chip. The soundstage is much wider, the sound is more transparent, and there are more details. I use it with the Topping D70 pro Sabre as a preamplifier. Good punch. I could never imagine that my Heco Victa Prime 302, which I want to change, would sound so good. David's kindness was the reason I bought AUDIOPHONICS MPA-S125NC. Thank you very much, David!
Lacking Some Detail and Control.
The aim was to replace my Musical Fidelity KW500 with something physically smaller.
I paired the MPA-S125NC power amp with a Lehmann Black Cube headphone/preamp, which I know very well with various headphones and have for a short time used it as a pre-amp combined with a class A/B power amp.
I initially just listened to music to give it a fair test, after a couple of evenings listening, these were my thoughts. Pros: wide soundstage; pretty good instrument positioning; fairly musical / Negs: lack of detail in bass and generally getting a bit muddled in complex layered tracks.
I switched to some test tracks:
1) Elbow, Asleep in the Back. This trips up many systems, the sibilance on this track can make it almost unlistenable if it is not well controlled. Not a total failure here, but was struggling a bit.
2) Clearlake, Lido. A layered album. Struggling to keep it from becoming messy.
3) Animal Collective, Feels. Again struggling to keep control of everything, sounded too harsh.
4) Pepe Deluxé Queen of the Wave. Could quite get the power and majestic and theatrical quality out.
There were other test tracks, but the above were the ones to highlight what I believe are the issues.
Conclusion. Just not good enough to replace the KW500. Perhaps this is a bit of an unfair comparison as the KW500 was a lot more expensive. However, I do not feel I can live with the MPA-S125NC as a main system component.
AUDIOPHONICS MPA-S125NC RCA
I am the proud owner of a preamp and power amplifier combination from a French manufacturer of first-class tube amplifiers. I actually ordered the small Audiophonics power amplifier with the intention of reducing the high power consumption of the tube combination when using it as a home cinema sound system (the tube power amplifier has 12 power tubes). At the weekend I had the opportunity to "test" the Class D power amplifier for the first time. To put it briefly: what the small power amplifier delivers in combination with the tube preamp is simply a small sensation. The sound is powerful and warm. The stage is large. Instruments can be located precisely. Vocals sound simply fantastic. I had not even remotely expected that from a power amplifier that costs less than a tenth of the purchase price of the preamp. The large tube power amplifier will probably only be used rarely in the coming weeks. Instead, I am looking forward to many hours together with the little "magic box". Thanks to Audiophonics. What you deliver for this price is simply unbeatable.
The Audiophonics MPA-S125NC incorporates a Hypex Ncore NC122MP power amplifier module. This is a solid base to build a powerful stereo HiFi system,...
