AUDIOPHONICS PA-S125NC XLR Class D Stereo Amplifier NCore 2x75W 8 Ohm
The Audiophonics PA-S125NC XLR integrates a Hypex NCore NC122MP power amplification module. This is a solid basis for building a high-performance stereo HiFi system, capable of delivering 2x75W under 8Ω.
By buying this product you get 36 loyalty points
Reference : 13693
369,00 €tax incl.
307,50 € tax excl.
Audiophonics PA-S125NC XLR Amplificateur de puissance NCore 2x75W 8Ω Noir
The Audiophonics PA-S125NC XLR integrates a Hypex NCore NC122MP power amplification module. This is a solid basis for building a high-performance stereo HiFi system, capable of delivering 2x75W under 8Ω. On a single double-sided PCB, it features a low-power power supply for standby, a high-performance disconnect power supply but above all a highly efficient Class D amplification circuit.
The amplifier used on this NC122MP module offers a high efficiency of 92% and allows it to be used for very different uses, whether for studio use or to be integrated into a high fidelity audio system. The distinctive characteristics of this amplifier are its response in linear frequency, whatever the charge impedance and consequently its restitution of a high transparency, its très low distortion, but also its très low EMI radiation rate. The amplifier control is based on a self-oscillating phase-shift loop, taking into account the response only at the output of the loudspeaker, always with a view to transparency and sound precision.
The main SMPS power supply to the amplifier is a half-bridge converter "Half Bridge">"Half Bridge" regular, high power and high efficiency, with synchronous rectification on the main output rails. An ideal power supply to provide this Class D amplifier with the power it needs.
In order to be compatible with supply voltages of 100-120V and 200-240V, the power supply is equipped with an automatic input voltage doubler.
NCore Technology
NCore amplifiers are the first Class D amplifiers to approach the performance of operational amplifiers but also to surpass them in terms of sound reproduction quality. Thus, they are able to deliver a clear, rich and musical sound while remaining compact. This NCore technology combines the stability of Hypex's UcD series amplifiers with lower distortion and output impedance.
100% Aluminium case integration
We integrate this Hypex NCore NC122MP amplifier into a 100% black brushed aluminum housing. This case offers an elegant finish. Its thick walls give it a high resistance, allowing it to effectively protect the components. The natural conduction of Aluminium and a studied air flow allow the heat produced by the module to be dissipated. In addition, the housing is silkscreened on the front with the NCore logo and on the back with the nomenclature of each input/output.
Its very compact size with a small width allows to reduce the space requirement as much as possible, thus offering high performance in a limited space. This amplifier does not have a decoupling capacitor. As a result, it allows the DC component of the signal to pass through. It is therefore strongly recommended to make sure that your source does not have a DC output component. The DC protection of the module remains permissive by switching on at 12VDC.
On the connector side, there are speaker terminals at the input of the Mini XLR stereo and at the output. In addition, there is a trigger input in 3.5mm Jack format. This last one allows to switch on the module with a signal of a DC voltage of 5V to 12V to synchronize it with an amplifier having this type of output. It is also possible to chain 2 amplifiers and switch them on simultaneously by controlling only one, the input being transformed into an output if the power button of one of the amplifiers is activated. Finally, a LED on the front panel indicates the status of the module and therefore lights up if a DC voltage is detected at the output.
Audiophonics PA-S125NC review by Qobuz
" The Audiophonics PA-S125NC amplifier, while offering the compactness and excellent performance of a switching model, offers a sound quality that is generally rather sweet over a large part of the audio spectrum, yet very muscular in the bass. "
Test du Audiophonics PA-S125NC par Qobuz
Testing the PA-S125NC in its version with RCA outputs. Same sound performance as the Mini XLR model.
Product typePower amplifier
Amplifier classClass D
Power2x75W 8Ω @ 1kHz THD = 1%
2x125W 4Ω @ 1kHz THD=1%
2x37W 8Ω @ 10Hz - 20kHz THD=0.0015%
2x62W 4Ω @ 10Hz - 20kHz THD=0.0015%
THD+N0.0015%
SNR118dB
Output noise30µV
Frequency response10Hz - 50kHz
Efficiency92%
Gain25.5dB
Input sensitivity125W 4Ω @ 1.17Vrms
Channels2 (Stereo)
Amplification technologyNCore
Input1x Mini XLR
Input / OutputTrigger 5-12V DC
OutputSpeaker terminals
Housing material100% Brushed Aluminium
Power supplyMain : IEC (cable included)
Trigger : Jack 3.5mm 12V (cable sold separately)
Dimensions28.7 x 10 x 6cm
Weight1310g
NC122MP
InputXLR
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)75.0
Excelent power amp in my system
I am very content with this amplifier. The system in my dining room:
Qobuz - Bluesound Node 2 - Mytek Brooklyn DAC - Audiophonics PA-S125NC XLR - 2x ATL 3-way floorstanders (4 Ohm). The Audiophonics PA-M250NC XLR deliver a detailed, clear and transparent sound in my dining room (appr. 5x5 m) with more than enough power for my 4 Ohm 3-way floorstanders. I like the compact design.
This review has been posted for AUDIOPHONICS PA-S125NC XLR Class D Stereo Amplifier NCore 2x75W 8 Ohm
The Audiophonics PA-S125NC XLR integrates a Hypex NCore NC122MP power amplification module. This is a solid basis for building a high-performance...
