ALSOZONE PAM153 3-Channel Power Amplifier
New
The ALSOZONE PAM153 is a multichannel class D power amplifier designed to drive speakers in Hi-Fi and home cinema installations. Each channel integrates a TPA3251 chip in PBTL configuration and delivers up to 150 W; the GaN power supply and 3eAudio's PFFB technology help maintain a stated distortion of 0.0003% into 8 Ω.
By buying this product you get 42 loyalty points
Reference : 22723
429,00 €tax incl.
357,50 € tax excl.
ALSOZONE PAM153 3-Channel Power Amplifier TPA3255 3x150W 4 Ohm
ALSOZONE PAM153: Front view
The ALSOZONE PAM153 is a class D multichannel power amplifier designed to drive speakers in Hi-Fi and home cinema installations. Each channel integrates a TPA3251 chip in PBTL configuration and delivers up to 150W; the GaN power supply and 3eAudio's PFFB technology help maintain a stated distortion of 0.0003% into 8Ω.
Intended for systems requiring several amplification channels, it combines balanced and unbalanced inputs, two-level gain adjustment and several power-on modes, including 12V trigger and automatic activation on signal detection. Its modular design and built-in protections make it easier to integrate and maintain in a multichannel installation.
ALSOZONE PAM153: Class D multichannel amplification
The ALSOZONE PAM153 is a multichannel power amplifier designed for Hi-Fi, home cinema and professional audio installations. Each channel relies on a TPA3251 chip configured in PBTL and delivers up to 150W, while the high power density GaN power supply provides the current required by the speakers. ALSOZONE specifies a total harmonic distortion of 0.0003% into 8Ω, in order to preserve signal detail at high listening levels.
ALSOZONE PAM153: TPA3251 chip
ALSOZONE PAM153: PFFB
ALSOZONE PAM153: PFFB technology
Using an independent TPA3251 chip per channel allows each amplification output to be managed separately. This architecture supports a 2Ω impedance and a stated output current of 34A, making it easier to pair with various speakers and multichannel configurations. 3eAudio's PFFB technology complements the power stage by targeting a stable response, for controlled reproduction in Hi-Fi listening as well as in home cinema.
ALSOZONE PAM153: Inputs and gain adjustment
The PAM153 accepts balanced differential and unbalanced inputs, allowing it to integrate with consumer sources as well as professional equipment. The balanced connection helps reject noise induced on cables, particularly in installations with several devices or long connection distances. A two-level gain adjustment allows the amplifier's sensitivity to be matched to the source's output level and the various components of the system to be better balanced.
ALSOZONE PAM153: Rear view
ALSOZONE PAM153: Standby and 12V trigger
ALSOZONE PAM153: Power-on modes and integration
Three control modes allow operation to be adapted to the installation: power-on via button, 12V trigger or automatic activation upon detection of an audio signal. The 12V trigger input and output facilitate integration into a complete HiFi system, while the automatic mode switches the unit off after 20 minutes of inactivity. This management limits standby consumption and reduces heat generated when the system is not in use.
ALSOZONE PAM153: Modular design and protections
The modular design allows individual amplification modules to be repaired or upgraded without replacing the entire unit. According to the manufacturer, this approach can reduce long-term maintenance and upgrade costs by 30 to 40%. The PAM153 also integrates microcontroller-driven protections against overvoltage, overcurrent and excessive temperatures, as well as a power supply compatible with various mains voltages to facilitate deployment.
ALSOZONE PAM153: Inside view
Technical specifications
Product typePower amplifier
Channels3
Inputs3x RCA
3x Combo XLR/Jack 6.35mm
Outputs3x Speaker terminal output
Amplification chipTPA3251
Amplification typeClass D
Output power3x 275W @ 2Ω THD+N = 1%
3x 150W @ 4Ω THD+N = 1%
3x 80W @ 8Ω THD+N = 1%
Frequency response20Hz-30kHz
THD+NSingle-ended input: 0.0005% @ 4Ω / 0.0004 @ 8Ω
Balanced input: 0.0004% @ 4Ω / 0.0003 @ 8Ω
SNRSingle-ended input: 122dB
Balanced input: 125dB
Dynamic rangeSingle-ended input: 122dB
Input sensitivitySingle-ended input: 2V/1Vrms
Balanced input: 4V/2Vrms
CrosstalkSingle-ended input: -110dB
Balanced input: -120dB
Gain LowSingle-ended input: 21dB
Balanced input: 15dB
Gain HighSingle-ended input: 27dB
Balanced input: 21dB
Recommended speaker impedance2-16Ω
Supply voltage100-240V AC, 50/60Hz
Dimensions260 x 265 x 90mm
Weight3.3kg
Package1x ALSOZONE PAM153
1x Power cable
InputJack 6.35mm
InputXLR
OutputSpeaker terminal
Channel3
Amplifier chipTPA3251
Power (W)150.0
The ALSOZONE PAM153 is a multichannel class D power amplifier designed to drive speakers in Hi-Fi and home cinema installations. Each channel...
