AUDIO-GD MASTER 2 MK3 Power Amplifier
The Audio-GD Master 2 MK3 is a stereo power amplifier in a fully balanced dual mono architecture designed to drive speakers over a wide impedance range, relying on discrete stages combined with ACSS technology in order to maintain current-mode signal processing and limit internal conversions. It delivers up to 500W into 4 ohms, with Class A operation at the first power levels or up to 250W into 8 ohms, in order to ensure stable and continuous reproduction while maintaining a high dynamic reserve.
By buying this product you get 519 loyalty points
Reference : 22094
5 199,00 €tax incl.
4 332,50 € tax excl.
Audio-GD Master 2 MK3 Power Amplifier Class A Dual Mono 2x500W 4 Ohm
Thumbnail of the Master 2 MK3
Intended for high-fidelity configurations, it integrates XLR and ACSS inputs allowing selection between voltage or current transmission depending on the associated electronics, while its adjustable gain levels and input parameters (impedance and sensitivity) allow precise adaptation to the preamplifier. This consistency between input interface and power stages allows maintaining stable behavior on complex loads, while maintaining a low noise level and thermal dissipation ensured passively without the use of ventilation.
Audio-GD Master 2 MK3: Architecture and operation
The Master 2 MK3 is a stereo power amplifier based on a fully balanced dual mono architecture, each channel integrating its own amplification stages and dedicated power supply in order to ensure complete separation of signal and power paths. This design relies on discrete stages combined with ACSS technology (Audio-GD Current Signal System), which uses current-mode signal processing in order to limit internal conversions and maintain a direct signal path.
Beyond this structure, the amplifier operates without global feedback, while the "Linear Fidelity" output stages also operate without correction loop, which implies that linearity depends directly on circuit sizing and their stability. The assembly uses 80 ON Semiconductor (Motorola) power transistors, distributed across both channels in order to ensure high current capability at the output, directly usable at the speaker terminals.
Photo of the inside of the Master 2 MK3
Audio-GD Master 2 MK3: Power and output capability
The Master 2 MK3 delivers 30W in pure Class A, then extends its operation up to 250W into 8 Ohms or 500W into 4 Ohms in Class AB when current demand increases. This transition allows maintaining a constant bias current at low levels while releasing a higher power reserve during dynamic demands.
The output capability reaches up to 1000W into 2 ohms per channel, which reflects an ability to maintain stability on low impedance loads. This continuity between operating regimes allows maintaining consistent amplification behavior regardless of the requested power level.
Audio-GD Master 2 MK3: Power supply and electrical stability
The power supply is based on multiple toroidal transformers combined with a large filtering capacity, organized according to the dual mono structure in order to isolate the channels from the energy generation stage. This configuration allows maintaining a stable voltage while ensuring current reserve availability when speaker impedance varies.
The circuit also integrates a soft-start system, which controls the voltage rise at power-on in order to limit stress on internal components and on the electrical network.
Photo of the connectors of the Master 2 MK3
Audio-GD Master 2 MK3 : Connectivity and signal adaptation
The amplifier integrates XLR inputs as well as ACSS inputs, allowing to choose between voltage signal transmission (XLR) or current (ACSS) depending on the associated electronics. The input impedance reaches 94Kohm in XLR while it remains below 10 ohm in ACSS, with a respective sensitivity of approximately 2.2V RMS and 2mA RMS, allowing to adapt the amplifier behavior according to the connection mode used.
Two gain levels are available, 20dB and 26dB, allowing adjustment of input sensitivity according to the output level of the preamplifier, while maintaining a signal-to-noise ratio greater than 120dB. This configuration allows adapting the overall behavior of the amplifier to different systems, while maintaining operational consistency between the input section and the power stages.
Audio-GD Master 2 MK3: Thermal dissipation and integration
Operation in Class A up to high power levels implies a significant bias current, handled by a thermal dissipation based on large passive heatsinks. This design allows heat to be dissipated without the use of active ventilation, while maintaining continuous amplifier operation.
The whole is integrated into a aluminum chassis structured to separate the different internal sections, which helps limit interactions between power supply and amplification in high-power configurations.
Technical specifications
Product typePower amplifier
InputsXLR
ACSS
Outputs> 250W @ 8ohm
> 500W @ 4ohm
> 1000W @ 2ohm
Gain20dB
26dB
Frequency response20Hz - 100KHz (-3dB)
Input sensitivityXLR: 2.2V RMS
ACSS: 2mA RMS
Input impedanceXLR: 94KΩ
ACSS: < 10Ω
Total harmonic distortion plus noise (THD)0.03% @ 10W 8Ω
0.04% @ 50W 8Ω
0.05% @ 100W 8Ω
Signal-to-noise ratio (SNR)> 120dB
Channel imbalance< 0.01dB
Power Consumption250W static @ 230V (Two units)
Dimensions360x270x457mm
Weight82kg
Packaging2x Audio-GD Master 2 MK3 power amplifiers
2x Power cables
InputACSS
InputXLR
OutputSpeaker terminal
ChannelDual Mono
ClassClass A / AB
Amplifier chipN/A
Power (W)500.0
AUDIO-GD MASTER 2 MK3 Power Amplifier Class A Dual Mono 2x500W 4 Ohm
The Audio-GD Master 2 MK3 is a stereo power amplifier in a fully balanced dual mono architecture designed to drive speakers over a wide impedance...
