SMSL RAW-MHA1 Power Amplifier
The SMSL RAW-MHA1 is a compact Class D stereo power amplifier designed to drive passive speakers with high power while offering great integration flexibility. It is based on an Infineon amplification chip and features two operating modes, PBTL and BTL, allowing the available power to be adapted to different configurations.
By buying this product you get 23 loyalty points
Reference : 22479
239,90 €tax incl.
199,92 € tax excl.
Shipping date: 24-11-2026.
SMSL RAW-MHA1 Class D Power Amplifier Infineon BTL/PBTL 2x 160W 4 Ohm
SMSL RAW-MHA1
The SMSL RAW-MHA1 is a compact Class D stereo power amplifier designed to drive passive speakers with high power while offering great integration flexibility. It is based on an Infineon amplification chip and features two operating modes, PBTL and BTL, allowing the available power to be adapted to different configurations. In PBTL mode, it delivers up to 2× 160W into 4Ω or 2× 85W into 8Ω, while BTL mode can reach 200W into 4Ω or 345W into 8Ω.
The RAW-MHA1 features RCA and XLR inputs for receiving a signal from a preamplifier or analog source, as well as speaker terminals and a subwoofer output with an integrated low-pass filter. Its amplification stage achieves a THD of 0.004% and a signal-to-noise ratio of 104dB. Its Class D architecture also provides efficiency above 90%, limiting heat dissipation despite the available power. Its CNC-machined and anodized aluminum alloy chassis contributes to the overall rigidity and heat dissipation, while protection circuits against overheating, overcurrent and short circuits ensure safe operation.
With dimensions of 182 × 46 × 187mm, the SMSL RAW-MHA1 is therefore a compact and versatile power amplification solution for stereo Hi-Fi systems or BTL configurations.
SMSL RAW-MHA1: Infineon Class D Amplification and PBTL / BTL Modes
The SMSL RAW-MHA1 is based on an Infineon amplification chip and a high-efficiency Class D architecture. It offers two operating modes to adapt the amplification to the system configuration. In PBTL mode, it delivers up to 2× 160W into 4Ω and 2× 85W into 8Ω in stereo. In BTL mode, the amplifier operates in a mono configuration and can provide up to 200W into 4Ω or 345W into 8Ω. This architecture allows the RAW-MHA1 to be used both as a stereo amplifier and in a BTL configuration designed to provide higher power on a single channel.
SMSL RAW-MHA1: RCA, XLR and Subwoofer Output Connectivity
The RAW-MHA1 offers connectivity suited to different Hi-Fi architectures, with RCA and XLR inputs allowing it to receive either an unbalanced or balanced signal. The main outputs are speaker terminals, while a Subwoofer output allows a powered subwoofer to be connected directly. The latter features an integrated low-pass filter, eliminating the need to add an external filter for this connection.
Overview of the SMSL RAW-MHA1
1Volume control
2RCA input indicator
3XLR input indicator
4BTL indicator
5Protection indicator
6RCA/XLR input selector
7Power switch
8RCA input
9Subwoofer output
10BTL/PBTL selector
11Balanced XLR input
12BTL speaker output
13Right channel speaker output
14Left channel speaker output
15100-240V AC mains power input
16BTL XLR input
17BTL RCA input
Technical Specifications
Product TypeAmplifier
ChipInfineon
ChannelsStereo PBTL / Mono BTL
Inputs1x RCA
1x XLR
OutputsSpeaker terminals
THD0.004%
SNR104dB
Channel Separation89dB
Input Sensitivity / Impedance700mV / 22Kohm
Maximum Input VoltageRCA: 2.5Vrms
XLR: 5Vrms
Output PowerStereo PBTL: 2x 160W @ 4 ohms / 2x 85W @ 8 ohms
Mono BTL: 1x 345W @ 8 ohms / 1x 200W @ 4 ohms
Power Supply100-240V AC
Power Consumption40W
Dimensions182x 46 x 187mm
Weight1321g
Packaging1x SMSL RAW-MHA1
1x AC power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipN/A
Power (W)160.0
SMSL RAW-MHA1 Power Amplifier Class D Infineon BTL/PBTL 2x 160W 4 Ohms
The SMSL RAW-MHA1 is a compact Class D stereo power amplifier designed to drive passive speakers with high power while offering great integration...
