By buying this product you get 439 loyalty points
Balanced Dual Mono Amplifier Diamond Differential Design 2x100W
The Audio-GD XA-150 is a high-end balanced amplifier consisting of two separate mono blocks in pure Class A with a Diamond Differential Design architecture. This structure allows it to develop a power of 100W per mono block, with an exceptional sound quality.
Its extremely careful design integrates 4 toroidal transformers for a total of 1700W and numerous Audio Grade capacitors for a cumulative capacity of 180000µF. The non-feedback output stages include no less than 48 transistors. The power supply stage is composed of 8 pure Class A PSUs to provide all circuits with a perfectly clean electrical signal, essential for a transparent sound reproduction.
The result of this design is quickly noticeable: great musicality thanks to exceptional dynamics and a rich sound that is extremely detailed in every detail.
Class A has the particularity of having its active components always in conduction. The quiescent current remains higher than the output current, thus limiting harmonic distortion. The output signal of the XA-150 is therefore of excellent quality, due to the absence of this famous sine wave crossover distortion.
Product type | Balanced amplifier |
Amplification type | Dual mono Class A |
Power | 2x100W @ 8Ω |
Gain | 28dB |
Inputs | XLR |
Outputs | Speaker terminals |
Consumption (for two mono blocks) | 700W |
Dimensions (for one mono block) | 375 x 510 x 273mm |
Weight (for two mono blocks) | 90kg |
Input | XLR |
Output | Speaker terminal |
Color | Black |
Channel | Dual Mono |
Class | Class A / AB |
Amplifier chip | N/A |
Power (W) | 100.0 |
