AUDIOPHONICS HPA-DM750ET Power Amplifier Purifi 1ET9040BA
The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex SMPS1200A180 power supply boards, it is capable, with incredible ease, of delivering 2x750W into 4Ω or 2x375W into 8Ω, while offering exceptional richness and precision for a musical experience on a whole new level.
By buying this product you get 259 loyalty points
Reference : 18943
2 590,00 €tax incl.
2 158,33 € tax excl.
Shipping date: 09-09-2025.
Audiophonics Workshop amplifiers range
Audiophonics HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm
Audiophonics HPA-DM750ET : Front view
This Audiophonics HPA-DM750ET amplifier will integrate seamlessly into the vast majority of HiFi systems, and can even accompany the most demanding loudspeakers.
All components are housed in a solid aluminum case, sober and modern. The design of the housing also ensures efficient heat dissipation, considerably reducing the impact of interference on the signal.
Audiophonics HPA-DM750ET : Key features
Audiophonics HPA-DM750ET : Purifi 1ET9040BA Amplifier Modules
Audiophonics HPA-DM750ET : Two Purifi 1ET9040BA modules in a true dual-mono architecture
Purifi's latest Class D amplifier module, the 1ET9040BA, once again represents an exceptional solution, capable of delivering both high power and very low noise levels and incredible linearity. It's based on EIGENTAKT's proprietary second-generation amplification technology, ensuring perfectly transparent sound reproduction, respecting every detail of the audio signal. Performance correlated with impeccable measurements, both in terms of THD and IMD.
The Audiophonics HPA-DM750ET power amplifier features two Purifi 1ET9040BA modules in a dual-mono architecture, delivering 750W per channel at 4Ω while greatly reducing interference and distortion.
Audiophonics HPA-DM750ET : Hypex SMPS1200A180 power supply modules
The Hypex SMPS1200A180 switched-mode power supply is an ultra-high-efficiency model capable of developing a rated power of 1200 Watts in a compact footprint. It has been specifically designed and developed by Hypex to supply the 2 x 46V voltage required to operate the most demanding amplifier modules.
This high-quality, low-noise power supply meets the power requirements of the amplifier modules in every respect. What's more, the amplifier modules themselves have an excellent ability to reject power supply noise. As a result, the HPA-DM750ET is extremely insensitive to imperfections in the power supply network, and to voltage/current variations that can cause parasitic noise.
The Audiophonics HPA-DM750ET benefits from a truly dual-mono architecture, incorporating two Hypex SMPS1200A180 power supply modules, each responsible for efficiently and cleanly powering a Purifi 1ET9040BA amplifier module.
Audiophonics HPA-DM750ET : Proprietary interface "Buffer" board
One Texas Instrument OPA1656IDR OPA per channel is used. These are very low distortion AOPs offering the greatest transparency with very low THD. They are mounted on a socket allowing them to be replaced if necessary.
To suit all uses we have opted for 4 gain settings: +16.55dB (x6.72) / +22.7dB (x13.64)  / +28.75dB (x27.38) / 30.8dB (x34.67).
Settings available under the device.
Audiophonics HPA-DM750ET : Balanced and unbalanced connectors
The Audiophonics HPA-DM750ET power amplifier features simple but effective connectors for the vast majority of applications. Inputs include unbalanced RCA and balanced XLR. Output is simply via speaker terminals. A double trigger is also present (input and output), enabling the amplifier to be integrated into an automated on/off chain.
Audiophonics HPA-DM750ET : Connector diagram
1ON/OFF button
2Right channel balanced XLR input
3Right channel input switch
4Right channel single-ended RCA input
5Right channel speaker output
6Power connector
7Trigger input
8Trigger output
9Left channel speaker output
10Left channel balanced XLR input
11Left channel input switch
12Left channel single-ended RCA input
THD vs Frequency @ 4
Audiophonics HPA-DM750ET : THD vs Frequency measurement
THD+N vs Output power @ 1kHz
Audiophonics HPA-DM750ET : Mesure de THD+N vs Puissance
Frequency response @ 2.83V
Audiophonics HPA-DM750ET : Frequency response measurement
Product typePower amplifier
Number of channels2
Amplification typeClass D dual mono
Amplification modules2x Purifi 1ET9040BA
Output power (@ THD 1%)2x 375W @ 8Ω, 0.1% THD
2x 750W @ 4Ω, 0.1% THD
2x 1200W @ 2Ω, 0.1% THD
InputsBalanced XLR
Single-ended RCA
OutputsSpeaker terminals
Gain / Sensitivity16.55dB - 4.07V
22.7dB - 2V
28.75dB  - 1V
30.8dB - 0.775V
THD+N0.0003% @ 1W, 1kHz
0.0001% @ 10W, 1kHz
0.00006% @ 100W, 1kHz
0.000045% @ 400W, 1kHz
0.0003% @ 1W, 20Hz-20kHz
0.0001% @ 10W, 20Hz-20kHz
0.00015% @ 100W, 20Hz-20kHz
0.0001% @ 400W, 20Hz-20kHz
IMD0.0001% @ 1W, 18.5kHz+19.5kHz
0.0001% @ 10W, 18.5kHz+19.5kHz
0.0001% @ 200W, 18.5kHz+19.5kHz
Dynamic range140dB(A)
Output noise4.5µV(A)
Efficiency96% @ 1kHz, 750W, 4Ω
Output current40A
Supply voltage110-230V (switchable)
Total dimensions (WxDxH)435 x 355 x 73mm
Idle power0.1W
Weight4.8kg
Package1x Audiophonics HPA-DM750ET
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ChannelDual Mono
Amplifier chipPurifi 1ET9040BA
Power (W)750
6 reviews
Heureux!
Je viens de recevoir mon AUDIOPHONICS HPA-DM750ET, et sincèrement… aussitôt branché, aussitôt le voile s’est levé. Un vrai waouh immédiat à la première écoute. La scène sonore s’est ouverte, tout est devenu plus lisible, plus tendu, plus vivant.
Niveau mesures : distorsion ultra-faible, bande passante droite comme un i, dynamique énorme… mais ce n’est pas que des chiffres : à l’écoute, c’est incroyable.
C’est neutre, transparent, ultra précis, mais sans froideur. Chaque détail est à sa place, les graves sont d’une autorité rare, les aigus filent haut sans sécheresse, et les médiums sont super fluides.
Pour info, l’ampli alimente des Jenzen Illuminator de Troels Gravesen, donc des enceintes très révélatrices — et il les tient avec une aisance déconcertante.
Et pour situer son niveau : comparé directement à l’étage de puissance d’un Marantz Model 10 à 15 000 €…
Et honnêtement, le HPA-DM750ET s’en sort admirablement bien. On n’est pas loin du sommet.
Un mot aussi sur Audiophonics : service client sérieux, réactif, pro, avec un super contact humain. Franchement, c’est devenu rare et ça mérite d’être souligné.
Un rapport qualité/prix juste exceptionnel, une fabrication française de haut niveau, et une écoute qui dépasse largement les attentes à ce tarif.
Bravo Audiophonics
Je recommande sans la moindre réserve !
This review has been posted for AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm
Rapport Q/P incroyable
Son prix est déjà sans doute assez conséquent pour pas mal de mélomanes… sauf que quand je l’ai branché il ne m’a pas fallu plus de 10 secondes pour comprendre que j’avais affaire à un ampli inouï , au propre comme au figuré et qu’il ne retournerai pas chez Audiophonics.
Dire que je redécouvre toutes les œuvres que j’écoute depuis 40 ans est un doux euphémisme.
Il est excellent sur tous les critères , sur tout le spectre . On n’a accès à cette qualité d’amplification que sur des appareils habituellement au minimum 5 fois son prix. D’où mon titre. Ce sera mon dernier ampli , plus besoin de chercher autre chose.
Fredrik
Very nice power amplifier for demanding speakers (low impedance / high current). This amplifier is driving my Magnepan speakers with ease, and with total control without coloration.
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba un Rotel RB-1552MkII en clase AB.. y muy bien ... hasta que pones el Purifi 9040 + Preamplificador Gustard P26 (Testado también con preamplificador Audio Research SP17 y Vincent SV-94)... no sabe uno de como puede sonar tu sistema cuando la potencia sobra. Los típicos comentarios de que la clase D no suena natural..... y que me decían algunos antes de apostar por este amplificador se disiparon una vez lo conecté a mi sistema.... al segundo día de pruebas... ya le quité la pegatina de protección frontal del Purifi 9040, puesto que tenía muy claro que me lo quedaría.
Ahora está junto con el Audio Research SP17 sonando... muy bien la verdad, pero es que la sinergia con el preamplificador Gustard P26 de mucho menor coste es aún mejor!..por increíble que parezca y para mi gusto... hacen una sinergia excelente.
Nada como probarlo en tu casa, con tu sistema... y ver de lo que es capaz esta bestia, apostaría que sí das el paso.. te lo quedas.
Saludos
Impressive and immersive sound details !
Now getting the full sound detail potential and precision of my dynaudio confidence 20 using the latest very powerful power amplifier from Audiophonics
The difference with the also very good 2 cyrus X power in mono is perceptible : in the Bass and medium: more refined and overall more immersive soundstage and no fatigue at all !
Excellent service from audiophonic all the way !
System :
-Denon avc 4800h with Dirac bass control
-2 subwoofers : B&W 610
- Source : quobuz with Octavio streamer and Denafrips Pontus 2 DAC
/ vinyl : project X2 ( ortofon 2M black ) with project Ds2 tube preamp
 (3)
The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and...
