DAYTON AUDIO SA1000 Subwoofer EQ Amplifier 1x950W 4 Ohm
4.0 / 5
By buying this product you get 74 loyalty points
Reference : 5018
749,90 €tax incl.
624,92 € tax excl.
Shipping date: 19-06-2026.
Grantie 5 ans
Attention: The product is delivered configured in 110V. If your electrical network supplies a voltage of 220V (Europe), it is imperative to configure the device in 220V, as explained in the manual. An incorrect setting could damage your device.
The Dayton Audio SA1000 1X950W over 4Ohm is a high power subwoofer amplifier designed for the DIY enthusiast, installer and integrator of home theater systems.
This unique monaural subwoofer amplifier offers the raw power of a professional Hifi sound amplifier with the functionality and flexibility of a dedicated subwoofer amplifier. It can be configured to be stacked with other audio components. It includes removable parts for mounting in standard racks (2RU).
The Class AB output stage provides a clean and controlled output signal. From a performance point of view, the simple and effective PEQ and filter cutoff settings adapt the sound to your room environment.
Sophisticated circuitry with "soft clipping" protection provides cleaner transient peaks, while protecting your woofer from excessive travel with a switchable subsonic filter that suppresses information through a high-pass filter in the low frequencies (25Hz/20Hz).
4 position Bass-Boost adjusts to the frequency response without using the parametric EQ. This leaves the parametric EQ function to handle room modes on a too strong resonance peak (pressure effect or bass depression at a given location).
This amplifier can be used with the following subwoofers:
General characteristics :
  • Class AB output stage 1X450W 8 Ohm/ 950 W 4 Ohm with high efficiency power supply (86%).
  • Low frequency parametric EQ adapting the frequency response.
  • Automatic sleep mode.
  • Switchable Subsonic and Bass Boost Filters (4 positions).
  • High-pass output on RCA (12dB) to loop the return signal into audio distribution systems.
  • Can be easily converted between 2U racks.
  • Rugged steel chassis with brushed aluminium front panel.
  • Adjustment: Phase, Gain, Parametric EQ.
  • Input voltage 110 / 220V switchable via fuse
  • Automatic on/off or 12V trigger input on 3.5 jack for easy integration into automated systems.
Technical data :
  • Rated output power (0.92% THD): 490 watts at 8 ohms, 950 watts at 4 ohms.
  • Signal to Noise Ratio: 98 dB A weighted.
  • Efficiency: 86%.
  • Input Impedance: 12K ohms - Subsonic Filter: -3 dB @ 18 Hz, Q = 0.8.
  • Bass Boost: +3 dB @ 25 Hz, Q = 1;4.
  • High pass output: -3dB @ 80 Hz, 12 dB / octave.
  • Low Pass Filter setting: 30-200 Hz.
  • Phase setting: 0° -180°.
  • Parametric EQ frequency setting: 18-80 Hz.
  • Bandwidth Q-factor setting: 0.1-1.0 Q.
  • Adjustable input/output level: -14.5 dB to +6 dB.
  • Power consumption Power supply: 120/230 VAC, 50/60 Hz.
  • Stand-by consumption: 120V 24W, 230V 18.4W.
Weights and dimensions :
  • Dimensions: 49.15 cm (length) x 41.15 cm (width) x 18.29 cm (height)
  • Weight: 10 Kg
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)950.0
5 reviews
Excellent !
Acheté pour mon enceinte de basse Cabasse Saturn Sono, le mariage est parfait. La différence est énorme avec l'appairage de l'ampli Cabasse 250W pour subwoofer, trop basique. En effet, le caisson a une fréquence de coupure à 45hz -6db et donc ne descend pas bien bas d'origine (conçu pour un fort volume dans le grave). Grace au réglage bass boost à 30 Hz et à l'égaliseur réglé +6db à 45hz, le caisson descend enfin très bas. J'active le filtre subsonic pour ne pas surcharger là où ce n'est pas utile. Le 55 NDS est parfaitement maîtrisé et fait trembler les murs, un extrême grave ultra-propre, pas de distorsion à niveau élevé, le rendement de 101db/1watt fait que la puissance tirée de l'ampli reste modérée... J'aurai aimé découvrir cet ampli plus tôt...
This review has been posted for DAYTON AUDIO SA1000 Subwoofer EQ Amplifier 1x950W 4 Ohm
bof
Amplificateur parti en SAV au bout de 6 mois. Utilisé à 50% de sa puissance. Peinture de très mauvaise qualité (en comparaison de mes amplis Atoll).
Petite rectification le mote auto pour l'allumage automatique fonctionne mais l'ampli ne se mais en veille qu'au bout de 15 minute par contre avec le 12 v c'est instantaner voila :)
Bonjour deja concernant audiophonics super conseil par mails ensuite une fois que je me suis decider j'ai commander et j'ai reçu ma commande rapidement
Deballage de l'amplis whahh il pese une tonne :) super finition par contre le cable d'alimentation fourni est pour les USA pas grave un cable d'alim de pc fera l'affaire
Comme le dit alexandre il faut retourner le fusible le mettre tete en bas pour le 220 v
Ensuite l'allumage auto n'a pas l'air de fonctionnez par contre je parle pas de celui avec le 12v mais celui qui s'allume des qu'un signal arrive dans le rca
L'ampli possede tous les reglage que vous pouvez avoir besoin pour un sub
la j'ai un 30 cm de 200 W rms dessus et l'ampli est a 1/4 de sa puissance sinon le sub claque ...
Les bouton de reglage se rentre une fois qu'on a fini de reglez en apuyant dessus
a Savoir l'ampli detecte quant on envoi trop de puissance au sub la led bleu de fonctionnement clignote rouge (pratique)
je tenais a mettre un commentaire plutot detaillez car en france personne ne connais cet ampli mais c'est vraiment un super ampli dommage qu'il ne sois pas vendu au meme prix qu'au USA ....
Concernant ce qu'il se dit sur les forum americain pour moi aucun bruit de font meme volume a zero !
 (3)
Attention avant de brancher et mettre en service cette ampli de vérifier la tension d'utilisation....pour ce faire il faut regarder le sens de montage du fusible.....en fonction de sa position votre ampli sera en 110V ou 230V. Il faut regarder attentivement car il faut que les deux minuscules flèches soient face à face.
Hormis cela la finition de l'ampli est bonne pas eu réellement le temps de le tester.
